Total Rebuild Of '71 Evy
#136
Posted 19 December 2011 - 09:55 PM
Graham, You got a recipy for that one??
#137
Posted 19 December 2011 - 11:06 PM
#138
Posted 20 December 2011 - 12:37 AM
#139
Posted 21 December 2011 - 11:52 PM
Posted 14 January 2012 - 11:31 PM
Check this out..
http://www.citypowdercoating.co.uk/
#141
Posted 14 January 2012 - 11:46 PM
I see you looking at powder coaters(on another thread)
Check this out..
thanks for that, a bit closer to home to, excellent prices, have you used them B4?
#142
Posted 14 January 2012 - 11:47 PM
If i needed anything powdercoating them I'd use them.
Very well priced!!!
#143
Posted 15 January 2012 - 12:10 AM
I haven't but I've seen them used by other people with good reviews.
Very well priced!!!
thanks for the tip,.....I was gonna use por15 on the old girls subby, I'll ask them what they wold charge 4 it.
#144
Posted 27 February 2012 - 03:41 PM
readry to fit,....
found these wunderfull pins(cleco) in a treasure box and made a hedgehog
at least I know the cleco's work, give welding a go again tomorrow, been a while.....
#145
Posted 27 February 2012 - 07:33 PM
#146
Posted 02 March 2012 - 06:56 PM
the long over-due roof repair has started again, having tried the cleco pins I decided to loose them again as they stay not in place with a bit of metal bashing on siteue, so went back to the old clamps again.I can safely say the whole procedure is not an easy one,
I tacked the repair piece
seam weld the bit, (scandalous bad welding, it has been a while...)
sanded flat,
zinc primed it
tomorrow check, when primer has dried in, then seamseal and prime again
#147
Posted 02 March 2012 - 08:58 PM
#148
Posted 02 March 2012 - 09:06 PM
This repair seems to have been going for ages, lol, but very nice result. Bet you are chuffed.
things do take a bit time, getting started is the biggest hurdle,next few days I will do the other side and then the rear, but the rear needs a new rear panel at the same time, so a bit planning to do,....what to do first.....probably, brace arches and/to rear bulkhead, to stop movement, then cut out the bad rear panel, do roof repairs and put donor rear panel on,....that is my first thought. What you reckon?
#149
Posted 03 March 2012 - 04:37 PM
seaamsealed N/S roof gutter
starting on O/S front roof repair, pressy underneath that corner
cleaned the rust off, with grinder wire brush, thought as much, even bigger holes
marked for cutting out, another day
#150
Posted 03 March 2012 - 05:04 PM
Will really have to summon up some enthusiasm soon !!
Graham
