Fuel Tank Float Rubber Ring
Posted 09 February 2011 - 06:56 PM
Just a quick question.
The Rubber ring around the fuel tank float, should I leave it on or take it off?
Thanks,
Callum
Posted 09 February 2011 - 07:22 PM
It was fitted for a purpose, we know this because Rover (etc) were far too tight to fit something that isn't required....
Posted 09 February 2011 - 07:24 PM
It's my dad whos doing it for me !
Thanks,
Callum
Posted 09 February 2011 - 07:50 PM
Posted 09 February 2011 - 07:54 PM
We do still have it, but when you put it on it expands and falls off into the petrol.
Thanks,
Callum
Edited by MateyTheMini, 09 February 2011 - 07:55 PM.
Posted 09 February 2011 - 08:06 PM
This shouldn't happen, i suspect that the wrong grade of rubber has been used to manufacture the O rings
Posted 09 February 2011 - 08:11 PM
Thanks,
Callum
Posted 09 February 2011 - 08:57 PM
Posted 09 February 2011 - 09:00 PM
I don't suppose you sell one at MRA do you?
Thanks,
Callum
Edited by MateyTheMini, 09 February 2011 - 09:02 PM.
Posted 10 February 2011 - 02:34 AM
I have seen the float rubber ring swollen on some Smith sending units but not on ones I have removed from Minis. I believe the purpose of the ring is/was to prevent rattling should the float come into contact with the inside walls of the tank. Therefore, you could do without it. There should be no functional change, just a potential rattle at completely full or nearly empty.
Posted 10 February 2011 - 10:50 AM
Fuel system rubber parts should be Buna-N (a.k.a. nitrile or NBR) or Viton. Viton is not more resistant to gasoline, but it does offer higher temperature resistance. I butyl rubber is not compatible with gasoline, nor is silicone rubber.
Ah! Thank you, i'll let him know later.. I think he was planning on taking it off as it just keeps dropping off, big help from you and MRA
Cheers,
Callum
