Smith Tachometer Help
29 replies to this topic
#1 Hegnirst
Hegnirst
  • 3,496 posts
  • Local Club: Hilltop Minis
Posted 09 February 2011 - 04:40 PM
i bought a centre Speedo :thumbsup: a water gauge, ammeter gauge and a tachometer (all smiths :trooper:)
But i cant find my rev counter anywhere! how to wire it, what it is, how much they are etc
can some one help me!
thanks (pics below)
Edited by Hegnirst, 09 February 2011 - 04:42 PM.
#2 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 09 February 2011 - 05:23 PM
I think what you have there is a very early (positive earth) tachometer for diesel engines.
The power connection on the insulated plate is mark "negative" which implies this is for positive earth. The two other connectors are labeled "gen".
For reference, see this closed eBay listing for another RVP tach:
http://cgi.ebay.co.u...G-/160517145039
Based on the comments in the eBay listing, I assume that a magnetic sensor (pulse "gen"erator) attached to the diesel engine provides "plus" and "minus" signals to the two terminals on the back of the tach.
I would not count on using this tachometer with your Mini.
#3 Hegnirst
Hegnirst
  • 3,496 posts
Posted 09 February 2011 - 06:03 PM
thankyou for the reply, so there is no way i can hook this up?
i love the look of it :thumbsup: its perfect for my rev range aswell
thanks
#4 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 09 February 2011 - 06:09 PM
You can play around with the tach and you MAY get it to work. However, let me point out two other problems that complicate using it.
1) The tach says it is for 24 Volts
2) The tach says it is scaled 2:1. Even if you found a way to connect this (with some form of signal generator) you may have to work a lot to get it to read correctly.
#5 Hegnirst
Hegnirst
  • 3,496 posts
Posted 09 February 2011 - 06:58 PM
:thumbsup: looks like i bought rubbish then :trooper:
#6 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 09 February 2011 - 07:18 PM
Not rubbish, just not the right thing. It's a truck tacho, the green and red zones show the driver how economically they are driving.
#7 Carlos W
Carlos W
  • 10,114 posts
Posted 09 February 2011 - 07:33 PM
It may in fact be very valuable!
Stick it on ebay with some decent pics and see what it makes!
I sold a smiths 2 inch 8 day wind up car clock a few years ago for 100 quid on ebay
#8 Hegnirst
Hegnirst
  • 3,496 posts
Posted 09 February 2011 - 11:32 PM
but i cant use it though :D
#9 Hegnirst
Hegnirst
  • 3,496 posts
i think i might, how do i test if it works though?
#10 Cooperman
  • 23,276 posts
Posted 09 February 2011 - 11:40 PM
A 5000 max rpm tacho would not be very suitable for a good Mini. Even an 850 will rev to 6000. Unless you have a very low powered engine and drive it very gently 5000 would not be anywhere near enough.
#11 1984mini25
1984mini25
  • 8,784 posts
Posted 09 February 2011 - 11:49 PM
Would be perfectly fine for a standard road mini though. Seriously how often on the road do you rev to and above 5k? Or maybe I should try driving round town in first screaming at 6k.
#12 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 09 February 2011 - 11:54 PM
or an 1100, they dont like to rev, and you dont take them over 5000 without starting to break a sweat if their going to survive!
#13 Hegnirst
Hegnirst
  • 3,496 posts
Posted 10 February 2011 - 12:11 AM
i can take mine to 5000 but i wouldnt want to go any higher, as the head, cam, rockers are all standard
#14 Hegnirst
Hegnirst
  • 3,496 posts
Posted 10 February 2011 - 12:12 AM
i agree, i just love the look of it though :D i hardly ever rev to 4K
#15 Hegnirst
Hegnirst
  • 3,496 posts
Posted 10 February 2011 - 12:13 AM
true, my 1300 metro lump can go to 5000rpm but really without a different cam, rollers etc your going to do more harm than anything surely? aha
