Li 2727 Laptop Factory Reset
7 replies to this topic
#1 steve26-2008
steve26-2008
  • 42 posts
Posted 05 February 2011 - 03:52 PM
I don't know if this is the right place so if not please forgive me. I have the above laptop and I'm looking to do a factory reset to speed it up. If anyone knows about pc's or has this laptop any help would be appreciated.
#2 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 05 February 2011 - 06:08 PM
Before resetting it, why not take everything off it and put it onto an external HDD. Then run the "Defrag" tool. Then right click on your C: Drive & Properties. Do a disk cleanup.
This should probably help with your speed issues :P
Other than that, if you want a totally clean start, just make sure you've got copies of all of your programmes, so you can put them back on again. And make sure you've got all your files off the computer.
You'll need the restore disks - If it's a newish one, you should be able to burn a couple from the partitioned drive. (There'll be a programme somewhere on your computer to make them) - If it's an oldish one, you'll need the OS disk & the drivers & utilities disk. Oh - And your OS Key - Which is sometimes on the computer itself, on a sticker.
Oh - and don't do a "system restore" :crazy:
Hope this helps! :-
#3 maryquant
maryquant
  • 932 posts
  • Local Club: minidesigner.co.uk
Posted 05 February 2011 - 06:27 PM
During the boot process, press the F8 key at very frequent intervals, until the menu
"Advanced Boot Options" appears. That will give you the "Repair your Computer"
function. Once Windows has loaded a few files, "System Recovery Options" will come up,
select the option "Fujitsu Siemens Computers Recovery" with the sub-item "Easy backup and recovery
of your system". and away you go...
You will loose everything on your pc if you do a factory restore though, so make sure you have backups of everything.
#4 The Colonel
The Colonel
    Previously known as Jackhammer
  • 197 posts
  • Local Club: setting up my own one
Posted 05 February 2011 - 06:47 PM
either do what is mentioned above.....or just do a standard windows install and get all the drivers off there website its very simple ive got the same machine just back everythign up first!!
#5 maryquant
maryquant
  • 932 posts
Posted 05 February 2011 - 06:57 PM
Dont do a standard windows install! Chances are you will screw up the hidden partition which contains all of your operating system, drivers, pre-loaded software, license keys etc.
It will change the MBR (master boot record) effectively rendering that data useless.
Edited by maryquant, 05 February 2011 - 06:58 PM.
#6 steve26-2008
steve26-2008
  • 42 posts
Posted 05 February 2011 - 09:02 PM
I have tried using f8, the advanced boot option appears but no function to repair the computer.
#7 maryquant
maryquant
  • 932 posts
Posted 05 February 2011 - 11:44 PM
What options do you get when you press F8?
The alternative is Shift-F10
#8 danrock101
danrock101
  • 2,478 posts
Posted 05 February 2011 - 11:59 PM
this is easier and faster + your computer ends up faster than it would if you were to use the recovery partion, if you have disks then only use the O/S disk and then download the drivers after
