Improve Mini Performance Mpi
5 replies to this topic
#1 Will#26THRacing
Will#26THRacing
    Starting My Mini Up
  • 4 posts
Posted 03 February 2011 - 05:25 PM
Hi everyone i have just got my first ever car its a Rover Mini Cooper Sport 1.3i 2000. I have stripped the engine down to give everything a once over and a clean and i was wondering what is the best way to increase performance, everything thats on the car is standard. So what would be the first things on your shopping list.
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 03 February 2011 - 06:18 PM
If you're wanting more than 90hp, replace the ECU for a mappable version.
#3 andymini12
andymini12
  • 812 posts
Posted 03 February 2011 - 06:21 PM
Also if you got the engine in bits you might as well put a better cam in maybe more of a mild road one and do some head work so port and polished etc.
#4 RayBoogs
RayBoogs
  • 1,109 posts
Posted 03 February 2011 - 07:12 PM
swifttune sw5-07 cam is a great road cam and probably the best suited one for the MPi, and also a big valve cylinder head. but if your going for big power you will be limited by the ECU.
#5 jamesmpi
jamesmpi
  • 1,940 posts
Posted 03 February 2011 - 07:18 PM
probably best having a search through the mpi/spi problems and technical area as various people have posted bit'n'pieces about increasing the performance of an mpi....
Upping your power is a simple matter of how much are you prepared to pay?
Low(ish) cost options involve keeping your engine as it is and adding a stage 1 kit which basically involves adding a better air filter and exhaust....
If you want to spend a bit more then as already mentioned, changing the CAM is a good option (i would recommend the swift tune SW5 CAM). You could even change the diff in the gearbox as a standard 2.76 diff is in there purely for economy, not acceleration.
Pushing the budget level higher will involve reboring to 1293 or 1340 or even 1380 and adding a better cylinder head etc but again, as mentioned already a reprogrammable ECU will be a good option if going this route.....
Edited by jamesmpi, 03 February 2011 - 07:20 PM.
#6 joel93
joel93
  • 148 posts
  • Local Club: h.p.m club
Posted 03 February 2011 - 08:51 PM
the basics are induction kit, plugs, lcb manifold and exhast (RC40 recomended) this willl giv you approx 5-8 bph increase . more power means cams, rocker rollers and head changed approx 25-35 bhp increase depending on head and cam stage.
