Hi guys I'm replacing my fuel sender unit and just wanted to check if the rubber seal goes behind the unit or between the unit and locking part???
Cheers rob
Fuel Sender Unit
bobbym18
, Feb 02 2011 08:22 PM
5 replies to this topic
Posted 02 February 2011 - 08:22 PM
Posted 02 February 2011 - 08:27 PM
Cheers rob
between the sender and the tank would be my logic.
Posted 02 February 2011 - 08:35 PM
as above, between the sender and the tank! that's where you need it as it creates a seal that stops the fuel from getting out
Posted 02 February 2011 - 08:57 PM
Cool thanks, do I need to use any gasket sealant on the rubber seal? Or will it be alright without?
Posted 02 February 2011 - 10:20 PM
No sealant will be needed if the surfaces are clean and the gasket is new. If you are re-using an old gasket that is hard and cracked, a thin coat of non-hardening, fuel resistant gasket sealant will help prevent leaks. Under NO circumstances should you use RTV silicone sealants on any fuel related parts.
Posted 02 February 2011 - 10:29 PM
Yea its a new one so its all goooood. Cheers guys!
