Magic Wand
11 replies to this topic
#1 mini77
mini77
  • 581 posts
Posted 31 January 2011 - 02:04 PM
What years did the magic wand gear stick last for? Should a 1969 mini 1000 have one?
Edited by mini77, 31 January 2011 - 04:34 PM.
#2 mini77
mini77
  • 581 posts
Posted 31 January 2011 - 05:04 PM
bump
#3 Tupers
Tupers
  • 4,143 posts
Posted 31 January 2011 - 05:20 PM
bump
You do realise most people are still at work don't you?
I found this by using the search function on here. By the sounds of it your car should have one
The 4-syncro magic wand gearboxes as fitted to the Mk2 and Mk3 (up until introduction of rod change) also had a special adaptor plate bolted to the remote style diff housing, instead of the unique 'tower' diff housing fitted to the earlier 3-syncro magic wand gearboxes.
Shown on right here:
http://www.somerford...?forumid=250646
Quote:
"From late 1968 when the gearbox went over from 3 to 4 syncromesh, they shared the same differential housing too - prior to that, the direct gearchange had its own unique diff housing with a small gearchange tower on it."
"Saloons and estates were re-engineered for rod gearchange for the 1973 model year. Vans and Pickups did not loose their direct (magic wand) change until the end of 1975."
#4 mini77
mini77
  • 581 posts
Posted 31 January 2011 - 05:25 PM
thanks! sorry :)
Edited by mini77, 31 January 2011 - 05:26 PM.
#5 simon8201
simon8201
  • 11 posts
Posted 31 January 2011 - 05:45 PM
My 1969 mk2 mini doesn't have a magic wand. I think it may well be a mark one thing.
#6 mab01uk
mab01uk
  • 12,413 posts
Posted 31 January 2011 - 06:10 PM
Even some Mk3 850 Mini's had a magic wand...........the magic wand was available at the same time as remote change in MK1, 2 and 3. The magic wand was usually fitted to the basic 850 saloon models and commercials until the rod change gearbox became standardised across the range.
Edited by mab01uk, 31 January 2011 - 06:11 PM.
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 31 January 2011 - 08:32 PM
Pretty much as above, 1973 is about the last of the MW's
the 850 and commercials were the last to change to Rod.
The 4 synchro remote replaced the Magic wand in the mini 1000's in about 1968 ( sometime during MK2 production ), so unless yours is an 850 or Commercial, then yours would have originally has a 4 synchro remote.
#8 mini77
mini77
  • 581 posts
Posted 31 January 2011 - 09:45 PM
Its a 1969 mini 1000...
Could it have just been one of the last to come of the production line?
#9 mab01uk
mab01uk
  • 12,413 posts
Posted 31 January 2011 - 10:41 PM
The books say: "Mini Mk2 - In contrast with the 850 model, the 1000 received the Cooper type remote gearchange and higher 3.44:1 final-drive ratio."
However many slightly 'mixed up' variants of all Mini's have turned up over the years and many ex-production line workers have confirmed mistakes were made or parts substituted to keep production going, especially during strikes or just to use up remaining stocks of end of line components during a changeover to new models being phased in or out.
Edited by mab01uk, 31 January 2011 - 10:42 PM.
#10 IWasNotYetBornIn1959
  • 106 posts
Posted 01 February 2011 - 07:39 AM
It's quite obvious why 850 kept the magic wand ... they are prone to Pottering the roads !
#11 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 01 February 2011 - 08:31 AM
#12 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 01 February 2011 - 08:34 AM
bearing in mind during that era they were producing 1/4 million minis per year (nearly 1000 per day) i doubt many were hanging around for long....
