I put together something to help you with the fuel gauge. Please download this and contact me with your questions:
http://home.mindspri...Instruments.pdfRegarding the 'T' piece, I believe Mini Spares sells them. Your new gauge is electric and will require a new wire be pulled through the firewall (assuming you aren't currently running an electric oil pressure gauge).
The tach connection on coil (-) will be the coil terminal with the wire going to the distributor. Later cars may well have had a wire already run behind the dash for a tach, early cars did not. Look for a white wire with a black tracer. This is the "normal" color code for a tach wire connection.
The volt-meter wire connection is up to you. Your web site implied that you have installed stereo equipment in your car. You should be able to use any of the switched power connection points you used for the stereo. You don't want the (typically yellow wire) connections used to maintain memory presets... you want a switched connection.
Earth connections will be any clean, bare metal point on the car chassis. As before, your stereo will have several black wires routed to chassis ground and you should be able to tap into any of those connections. All your new gauges will need earth and switched power connections.
Temp gauge. Where are you to wire it up? If you're not using the stock sending unit and its gauge, you should be able to use the wire that's already in the harness. Replace the stock sending unit with your new one, connect the stock wire to it. Behind the dash, find the other end of this wire and connect it to the input for your new digital gauge.
