Converting To Cable Gear Linkage
Posted 24 January 2011 - 10:39 AM
I can't see it being particularly difficult if a nice bracket was made up for the back of the engine- and the assembly used from a modern car- can anyone see why it couldn't be done? The only thing I'm not sure about is it has to be reliable!
Posted 24 January 2011 - 12:06 PM
So what's your next project, redisigning the wheel?
Posted 24 January 2011 - 12:15 PM
Posted 24 January 2011 - 03:54 PM
haven't looked into it yet but i'm toying with the idea of setting a servo shift up to run a sequential change.
Posted 24 January 2011 - 04:01 PM
Well it seems like every car manufacturer "redesigned the wheel" as every single modern car I can think of has a cable gear change. Hence why I was wondering if it was feasable to mount a modern (and proven to work across millions of cars) cable type gear change, or whether the A series gearbox is too clunky for it to work nicely.
Most modern cars don't have an easy direct run from the gearstick to the transmission, so use cables.
We're able to make a direct run with a rod, so leave it be, it's much nicer and easier to get right.
Similarly the mini has a hydraulic clutch, look at how long it took a lot of other manufacturers to do that, into the 90's and later there's cable clutches everywhere!
Posted 24 January 2011 - 04:45 PM
Posted 24 January 2011 - 08:58 PM
All the modern cars I've owned or looked at had cable actuated clutches. A cable has to be cheaper and quicker to install on the production line than a hydraylic system.Similarly the mini has a hydraulic clutch, look at how long it took a lot of other manufacturers to do that, into the 90's and later there's cable clutches everywhere!
Posted 24 January 2011 - 09:30 PM
True - but a Hydraulic Clutch is better!
Posted 24 January 2011 - 09:54 PM
