Centre Binnacle Wiring Conversion
benno1275
, Jan 23 2011 09:08 AM
8 replies to this topic
Posted 23 January 2011 - 09:08 AM
Good morning all
My car is a 84 with multiple instruments, tacho and Im going to be fitting three clock centre binnacle I have a original harness for the speedo so can I solder that into my original loom and is there anything I should look out for alonng the way?
Thanks in advance
Thanks in advance
Posted 23 January 2011 - 09:20 AM
I've just bought the conversion loom from minispares, you can have a look at that if you like?
Posted 23 January 2011 - 09:58 AM
I was gonna get one because they make life a lot easier but I've spent enough now and I'm on a tight budget so I'm sure I can get that harness matched up to my loom wasnt sure if someone had already done it then they could shed some light for me??
We doing then meet next month aswell?
Posted 23 January 2011 - 10:37 AM
Thinking about it there may be guide in the FAQs, I'm sure i've seen one.
Posted 23 January 2011 - 10:44 AM
Thanks mate
Posted 23 January 2011 - 11:22 AM
Yes don't use solder..... it really is not a good wire connection method within a car, due to the very fact that as you solder the joint some solder will wick up the wire and cause a brittle joint, as the car vibrates (mainly secondary harmonics - road undulations coupled with engine oscillations) causes the joint to fatigue
Posted 04 June 2012 - 05:54 PM
Has anyone done the conversion to the centre 3 clock binnacle from the 2 clocks at the side. I need to connect the wiring that went into the two clocks and dont know what wires are needed to be joined .. anyone help
Posted 18 June 2012 - 10:14 PM
got mine done..easy
Edited by mini-adam, 22 July 2012 - 10:49 PM.
