Radweld
9 replies to this topic
#1 087dave
087dave
  • 952 posts
Posted 21 January 2011 - 10:41 PM
Hi all ,i have a water leak out of my heater inside the car
i think it is coming from the matrix,
i was thicking of putting in radweld before buying a new matrix
does the radweld last long?
is this stuff any good or are you better off buying a matrix?
#2 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 21 January 2011 - 11:00 PM
radweld is awful stuff, use wynns radiator stop leak. although for how easy it is you might as well just change the heater matrix.
#3 Mini Adam
Mini Adam
  • 682 posts
Posted 21 January 2011 - 11:06 PM
My dad used radweld in his Ford Focus Estate V reg 3 weeks back now. (Oil was getting into the water system thus casuing the car to overheat). It's done him well so far. For the £10 it's cost him it's worth it so he doesn't have the hassle of having to rush to find a new car. He seemed pretty impressed with the results :(
#4 minidream94
minidream94
  • 1,233 posts
Posted 21 January 2011 - 11:07 PM
yeah rad weld is shicking, my mate blew his rad up as it was full of rad weld, not a good ending, he had to rebuild the engine :S
#5 Abminis
Abminis
  • 89 posts
Posted 21 January 2011 - 11:15 PM
radweld nasty gear
keep away from it
personaly i would fix the leak
#6 charie t
charie t
  • 3,153 posts
Posted 21 January 2011 - 11:20 PM
Its awful, its designed as a "get you home" fix. its not meant to be used as a permanent repair.
It should be flushed out of the system when the repair has taken place.
If i were stuck on the moors with a water leak, then i would still think twice about using it
#7 rick.spi
rick.spi
  • 1,686 posts
  • Local Club: "WOT NO BRAKES"
Posted 21 January 2011 - 11:27 PM
dont bodge it, this is why minis have such a bad reputation. fix it properly and its over with!
#8 mattsbmw
mattsbmw
  • 192 posts
Posted 22 January 2011 - 06:30 PM
Fix it properly, would only use rad weld as an absolute last resort.
#9 starletman
starletman
  • 249 posts
Posted 22 January 2011 - 06:37 PM
quote]
My dad used radweld in his Ford Focus Estate V reg 3 weeks back now. (Oil was getting into the water system thus casuing the car to overheat). It's done him well so far. For the £10 it's cost him it's worth it so he doesn't have the hassle of having to rush to find a new car. He seemed pretty impressed with the results :thumbsup:
[/quote]
Its ok to postpone something thats already broken,but for the sake of a £30 matrix and half an hours work i would replace it.
#10 MiniLuke
MiniLuke
  • 1,205 posts
Posted 22 January 2011 - 06:40 PM
Bypass the heater for now whilst you source a new matrix. :thumbsup:
