Micra Engine Frames.
105 replies to this topic
#76 Artstu
Artstu
  • 830 posts
Posted 16 September 2013 - 04:24 PM
I see Allspeed now have a Nissan K11 section! perhaps a subframe on the way?
http://www.allspeede....php/nissan/k11
#77 666junky
666junky
  • 1,225 posts
Posted 16 September 2013 - 04:54 PM
:w00t:    YES!!!
#78 al_reidy
al_reidy
  • 351 posts
  • Local Club: Geeks N Freaks
Posted 16 September 2013 - 06:26 PM
oh yeah, thats more like it! well spotted. lets hope it leads somewhere.
#79 Artstu
Artstu
  • 830 posts
Posted 17 September 2013 - 12:25 PM
Rob at Allspeed has confirmed that he is working on a subframe to take the Micra engine, November 2013 was his target, but feels it may run over a little.
#80 l_jonez
l_jonez
  • 1,453 posts
Posted 17 September 2013 - 04:49 PM
It's about time a frame was produced, I think the micra conversion could really take off if the frame is a reasonable price.
#81 Artstu
Artstu
  • 830 posts
Posted 18 October 2013 - 07:13 PM
A bit of bad news on the Allspeed frame for me.
Rob has confirmed that he is working with RS5F41 gearbox from the early pre-1998 ish 1.0L Micra which is smaller and lower geared than 1.3 gearboxes, , it also uses smaller drive-shafts, so for me it limits the usefulness considerably.
Some Micra owners do use the smaller box and shafts on the 1.3 engines, and the 160 mm clutch just about copes, hybrid 180 mm clutches have been home made to over come that issue, the lower gearing isn't such an easy fix though.
Fitting the later gearbox will also still mean some cut and shut driveshafts, because the Allspeed ones won't fit the bigger gearbox.
Edited by Artstu, 18 October 2013 - 07:14 PM.
#82 l_jonez
l_jonez
  • 1,453 posts
Posted 18 October 2013 - 11:40 PM
I still can't understand why people avoid the 1.3 larger box, me and several people have fitted them no problem. I ran the 1.0 box and gearing was to short for my liking.
Also when it came to the shafts I found the micra splines fitted the mini cv joint perfectly, so I just used the micra shafts bit with a section cut out of the middle and welded back together.
#83 666junky
666junky
  • 1,225 posts
Posted 19 October 2013 - 08:50 AM
Bugger.. I really need the whole 1.3 straight drop in plan.. The driveshaft thing is an issue too.
Hey ho, lets look for someone willing to make me one then!
#84 humph
humph
    How bad can it Be?
  • 1,092 posts
Posted 19 October 2013 - 12:57 PM
Disappointing.
#85 Artstu
Artstu
  • 830 posts
Posted 19 October 2013 - 01:00 PM
Disappointing.
It is, I hate to say it, but I think Rob has dropped a clanger on this one.
#86 lucas1amps
lucas1amps
  • Just Joined
  • 587 posts
  • Local Club: Weston Mini Muckers
Posted 21 October 2013 - 08:31 AM
well when i enquired he wanted 500+ for the frame and drive shafts my frame cost 50 quid to build so il rather build 3 more and get it right that pay that much
#87 Artstu
Artstu
  • 830 posts
Posted 21 October 2013 - 09:35 PM
Well it's a bent tie bar style, cheaper than the other variations.
http://www.allspeede...ndex.php/nissan
#88 666junky
666junky
  • 1,225 posts
Posted 23 October 2013 - 04:17 PM
disapointed even more after clicking the link :(
#89 R1mini
R1mini
  • 1,387 posts
Posted 23 October 2013 - 04:26 PM
Why?
#90 Artstu
Artstu
  • 830 posts
Posted 23 October 2013 - 05:11 PM
Why?
I imagine it is because She has a 1.3L CG13, therefore the mounts for the gearbox will be different, along with requiring different driveshafts.
