Some of the FEA testing that I have been running on a series of models based on both tried designs and new ones. I am applying a load of 1500N to the frame in one place which is far higher than it is likely to be subjected to under normal use but this should give a good factor of safety. Under heavy braking the total force excerted by the engine on the frame will be around 1000N spread over the three mounts. The suspension loads are taken by the subframe as originally intended. The model shown above is the most promising so far, only deflecting by 2.6mm. By comparison the models made from plate (assumed to be 16swg) were deflecting by 10mm+. The frame above is 30x30 16swg.The total weight of the new metal comes to under 9kg.
