Micra Engine Frames.
#16
Posted 28 February 2011 - 11:22 PM
Iain
#17
Posted 02 March 2011 - 01:28 AM
Yah i was going to say. Wasn't sure if its the same one he meantI was hoping to buy one from Dazzler but he seems to have sold up so I'm assuming I'd have to do it myself.
Iain
#18
Posted 12 March 2011 - 05:06 AM
#19
Posted 23 June 2011 - 02:24 PM
#20
Posted 23 June 2011 - 08:01 PM
bump , any prices yet ?
Who you asking?
#21
Posted 25 June 2011 - 07:56 PM
#22
Posted 25 June 2011 - 08:09 PM
#23
Posted 25 June 2011 - 08:24 PM
Iain
#24
Posted 26 June 2011 - 04:10 PM
Edited by evansisgreat, 26 June 2011 - 04:13 PM.
#25
Posted 26 June 2011 - 07:25 PM
#26
Posted 29 June 2011 - 09:31 AM
#27
Posted 29 June 2011 - 09:56 AM
#28
Posted 29 June 2011 - 11:37 PM
My current design which is still literally on the drawing board is based on replacing the sides of the sub frame with fabricated tube welded to the front member and rear turrets, providing clearance above for the engine. All of this will need to be tested first in solid works and then on my car before I put anything into production so please be patient.
As far as I am aware, unless there are some serious difference between a GTM and round nose Mini it should be ok.
Out of interest, would you guys be interested in the fabricated parts supplied for self fitting or would a ready built conversion frame be better? I am very aware of costs here!
#29
Posted 30 June 2011 - 11:01 AM
Keep us posted with development. When you've drawn up the prototype get some pics from solidworks up.
Good luck mate.
#30
Posted 30 June 2011 - 05:26 PM
Regarding the GTM - so long as the front member of the subframe and the towers are the same and retain their relationship then it should be OK. The tower mounts are pretty nuch the same as a Mini but with shorter bolts and the holes where the teardrop mounts would attach on a Mini front panel are used to secure the front end of the subframe to the GTM rear bulkhead plus a second pair of bolts are added with new holes in the subframe a little further out.
The only possible problems I see are with clearance around the front of the engine. From the pictures I'm hoping it won't be a problem and even less so if I can ditch that first cat under the manifold. If it is then there is scope in a GTM for the engine to move further back as there isn't a bulkhead in the way behind it but obviously this would make it a custom subframe and outside the scope of this exercise.
If you want a guinea-pig for putting a kit together let me know.
Just a thought for the kit idea and the need for a jig...... In most cases this has been because the sides of the subframe have been cut out and the engine dangled in place whilst the new sides were created around it so the jig was needed to keep the front crossmember and rear crossmember and towers aligned. If the sides are ready to go in with reasonably accurate location points/measurements established.... the jig could consist of 4 lengths of tube/angle - 2 that are tacked high on the towers/rear subframe and to the top of the front crossmember and 2 that are tacked low on the rear crossmember/towers and to the bottom of the front crossmember. They pass through the space that the engine and box will eventually occupy but if you don't need the engine and box in place to make the sides up that's not a problem. Couple this with removing one side at a time and welding (or at least heavily tacking) in the replacement side before you remove the other side and there should be no movement of the two original parts of the subframe in relation to each other. The "kit" could conceivably consist of two pre-fabricated sides and some instructions (plus sundries).
Iain
