Overdrive
15 replies to this topic
#1 Msmith3327
Msmith3327
  • 220 posts
  • Local Club: Torbay Mini Club
Posted 17 January 2011 - 06:35 PM
This is more off a head in the clouds question.
Has anyone ever fitted an overdrive or can they even be fitted to a mini gearbox, MG's have them with i think a transverse gearbox (probably the wrong word for it) but would they fit a mini gearbox???
Lets throw that one out there!
#2 MiniLandy
MiniLandy
  • 796 posts
  • Local Club: HAMOC
Posted 17 January 2011 - 06:41 PM
I'd also be pretty interested in this, my LandRover's got one in the Power Take Off of the transfer box.
Lack of a fifth gear is a massive problem in my mini, is an overdrive even possible?
#3 Msmith3327
Msmith3327
  • 220 posts
Posted 17 January 2011 - 06:44 PM
Have been reading the posts ref this and everyone os going on about 5 speed box's what i am looking at it the same as in an MG where you flick the button rather than change gear!
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 17 January 2011 - 06:45 PM
No...
Overdrives are units which are fitted to the back of ( or integral ) to the gearbox on the output shaft before the differential...
I can't think of any transverse fwd transmission which has an over drive, and I don't mean an overdrive gear which obviously most modern 5/6 speed transmissions have...
And the MG it not transverse it's rwd with a longitudinal engine ( or Vertical )
#5 Msmith3327
Msmith3327
  • 220 posts
Posted 17 January 2011 - 06:50 PM
Cheers Guessworks, I knew i was wrong on that transvers thingy. :huh:
#6 Msmith3327
Msmith3327
  • 220 posts
Posted 17 January 2011 - 07:18 PM
Have had a look on Minispares and can only find a 3.4 final drive, can anyone point me towards a new 3.1 final drive gear, and is it a straight swap with the final drive in my current 89 998
#7 [email protected]
[email protected]
    Minispares
  • Minispares
  • 3,229 posts
  • Name: Simon Jackson
Posted 17 January 2011 - 09:09 PM
http://www.minispare...ty=pb&pid=41995
Stock due in next few days
#8 wardyxxx
wardyxxx
  • 1,327 posts
  • Local Club: Leicester Mini Club
Posted 17 January 2011 - 09:34 PM
Guessworks to the rescue!
#9 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 17 January 2011 - 11:51 PM
Cheers Guessworks, I knew i was wrong on that transvers thingy. :D
What's wrong with the one you already have ?
ps...
got plenty of used ones...
http://www.guess-wor...play.htm?id=156
#10 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 18 January 2011 - 11:48 AM
There is plenty of room inside the end of a rod change box to accept a Laycock overdrive unit, but one would have to be specially made to fit in there. Much like the Mini clutch it would essentially have to be inside out and use concentric shafts to fit. It's a shame they never did this but by the time the rod change was introduced, overdrives were out of fashion and earlier boxes didn't have enough free space.
#11 Msmith3327
Msmith3327
  • 220 posts
Posted 18 January 2011 - 02:58 PM
Just looking for a better cruising RPM at the moment, as i do a lot of runs from Devon to London and at 3.765 - 1 it gets a bit loud
#12 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 18 January 2011 - 04:51 PM
one assumes the engine/box is not the original, the 3.1 final drive was standard fit to all minis from the mid 80's with only some models, eg City E and Spi cooper getting something different.
#13 Timtom
Timtom
  • 2,143 posts
Posted 18 January 2011 - 05:07 PM
I had a gearbox that went poof along with the 'new' gearbox i got a 3.1 final drive and on my 1275 it makes a lot of difference! I think i had a 3.4 (Guessworks now has said duff gearbox) but that would 'cruise' at 4K+ normally now it cruises at 3K. Blessing!
T
#14 Msmith3327
Msmith3327
  • 220 posts
Posted 18 January 2011 - 07:16 PM
I get 60moh at 4000 rvs ish so am guessing it actually 56 at 4000 which if guesworks website is right as it no doubt is i make it one of them 3.76 ones. So when i strip it and rebuild it i will be heading your way guess works for a 3.1 final drive :D
#15 ErnstBlofeld
ErnstBlofeld
    Starting My Mini Up
  • 4 posts
  • Local Club: Six Ex Mini Owners
Posted 31 August 2012 - 10:12 PM
On the overdrive side of things, and apropos of nothing, I do recall Longbridge engineer Charles Bernstein being interviewed many years back by "Mini Magazine." He said during the Metro's early years BL/ARG had looked at the Jack Knight 5-speed transmission and rejected it, but that there was a serious proposal to develop an overdrive unit.
