Need Help With Mini Differential Oil Seal
6 replies to this topic
#1 sean552uk
sean552uk
  • 133 posts
Posted 15 January 2011 - 08:27 PM
Hi i hope someone can help i ordered 2 mini differential oil seals to replace the ones on my gearbox. from here
http://cgi.ebay.co.u...e=STRK:MEWNX:IT
but after removing the first one, i have noticed that what i have been supplyed are bigger that what i have taken out! the one i have taken out is 7.5mm wide and the new one is 9.5mm wide. the old one has GACO ANGUS IND51023 written on it. the new one just has 31.7 47.6 9.5 written on it. the engine is a 1992 1275cc.
are the oil seals i have been given wrong or are they an 'after maket improvement'?
Thanks Sean
Attached File  oil_seal.JPG   1.12MB   7 downloads
Edited by sean552uk, 15 January 2011 - 08:29 PM.
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 15 January 2011 - 10:19 PM
or an "after market Cheap copy"....
They are correct dimensionally ( other than the thickness ) but are certainly not of the quality of the Angus Gaco seals..
Angus Gaco seals...
http://www.guess-wor...play.htm?id=170
or cheaper but still ok NAK seals..
http://www.guess-wor...play.htm?id=169
#3 sean552uk
sean552uk
  • 133 posts
Posted 15 January 2011 - 10:28 PM
hi yes they are correct dimensionally except for the thickness. do you think that they would work ok as they would stick out of the housing by 2mm if i installed them? or i'm thinking it would be best to just get the correct size seals? and try to send these back.
thanks
#4 sean552uk
sean552uk
  • 133 posts
Posted 15 January 2011 - 11:21 PM
decided its best to get the Angus Gaco seals from your shop Guess Works. thanks for the help sean
#5 MRA
MRA
  • 7,607 posts
Posted 16 January 2011 - 02:30 PM
As it is the main part of the seal that is sticking out then I would suggest that the chances are very low for keeping them in position and that the chances are high for the POT joint to rub on the seal and waer it out very quickly >_<
#6 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 16 January 2011 - 03:41 PM
I am curious. Is it possible that the seal is intentionally built that way in case the pot joint has a wear groove? That would provide a new unworn sealing surface and replacement of the pot joint could be avoided.
Thanks,
Ivan
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 16 January 2011 - 04:16 PM
Being thicker in section means you actually have less scope for 'positioning' the seal... the actual depth of the recess in the cover is about 10mm, so these would need to be pretty much pressed fully in, meaning you have very little choice where the 'seal' is to sit in relation to the pot.
