Mark
Edited by mini.30, 15 January 2011 - 07:18 PM.
Posted 15 January 2011 - 07:11 PM
Posted 15 January 2011 - 07:16 PM
Could say the same about cam belt covers
Posted 15 January 2011 - 07:25 PM
Posted 15 January 2011 - 07:28 PM
In my opinion a brake back plate is the part that the wheel cylinder and shoes mount to on drum brakes, not the splash guard from behind the discs
Mark
Posted 15 January 2011 - 07:34 PM
Posted 15 January 2011 - 07:36 PM
Posted 15 January 2011 - 07:38 PM
If its a track only car its fine to leave them off , theyre there to protect the brakes from dirt , spray n debri thrown up off the road, but they do keep a lot of water off the disc and pads surface if its been raining aswell
If its to be used on the road aswell though its an MOT failure if they're missing
I agreee that it is a matter of opinion, but in my opinion it is a splash guard not a back plate. I work as a Technician at Honda and many new cars don't have a full sheild like the mini does, part of this disc is still visible from the inside. I think you would be very unlucky to get pulled up on MOT for these being missing
Edited by 1984mini25, 15 January 2011 - 07:41 PM.
Posted 15 January 2011 - 07:52 PM
Posted 15 January 2011 - 08:06 PM
Rubbish, you are reading it wrong. it says it will fail if theAs above, mine have been off for two years and no problemIf its to be used on the road aswell though its an MOT failure if they're missing
It's not an mot failure, i took mine off when fitting my 7.5" brakes and had an mot a month later and it passed without even an mention.
it should be an mot failure if they do it strictly by the book really , if they were fitted as standard they should be there for the MOT . I'm not sure if it will
make any difference with if the car was built within certain dates but like i said if they play it strictly by the book they should be fitted .
MOT Testing manual << clicky its th bottom of the 3 options for test manuals , its under section 3.5 very bottom of the reasons for rejection " a brake back plate, wheel cylinder or caliper securing device loose, missing or excessively deteriorated "
personally my interpretation of it would be if its missing , it should fail
Posted 15 January 2011 - 08:14 PM
Rubbish, you are reading it wrong. it says it will fail if the<you> securing device</you> for any of the mentioned items is loose, missing or excessively deteriorated, not the shield itself. If it's not there then there is nothing to be secured, however is it is there and a bolt holding it is loose missing etc. then clearly a fail.As above, mine have been off for two years and no problemIf its to be used on the road aswell though its an MOT failure if they're missing
Posted 15 January 2011 - 08:18 PM
Posted 15 January 2011 - 08:20 PM
Agreed, the point being it's the securing device that is in question. I nearly have an MOT failure because I used a spring washer and plain nut instead of a nyloc nut on the lower front suspension pin, but after a short conversation about being there as standard he saw reason.Rubbish, you are reading it wrong. it says it will fail if the<you> securing device</you> for any of the mentioned items is loose, missing or excessively deteriorated, not the shield itself. If it's not there then there is nothing to be secured, however is it is there and a bolt holding it is loose missing etc. then clearly a fail.As above, mine have been off for two years and no problemIf its to be used on the road aswell though its an MOT failure if they're missing
As the same bolts that hold on the disk shields also happen to be the same ones that hold the calliper to the hub. Then yes it should fail, but more because of an insecure calliper than the shield itself.
Posted 15 January 2011 - 08:32 PM
Edited by Rob82, 15 January 2011 - 08:35 PM.
Posted 15 January 2011 - 08:44 PM
Sorry Rob82, "rubbish" is a little harsh i guess. We'll just disagree and leave it there.Rubbish, you are reading it wrong. it says it will fail if the<you> securing device</you> for any of the mentioned items is loose, missing or excessively deteriorated, not the shield itself. If it's not there then there is nothing to be secured, however is it is there and a bolt holding it is loose missing etc. then clearly a fail.As above, mine have been off for two years and no problemIf its to be used on the road aswell though its an MOT failure if they're missing
read the middle column luke , method of inspection , "presence and security of brake back plates, wheel cylinders and calipers"
key word being presence . not if they are present the must be secure . As ive said people will interpret it differently , and although i
dont agree with everybody , i can see it from their point , how they interpret the text and so wouldn't go telling them they are talking rubbish
As with mini.30 i am also a techinician with over a decade of experience so now how great dealing with VOSA rules n regs can be
Posted 15 January 2011 - 09:10 PM
Mark
