Starter Motor Test?
Posted 12 January 2011 - 07:09 PM
My mini will not start and it has been sugested that it could be the starter motor, does anyone have a method for testing a starter motor?
Many thanks,
Henri.
Posted 12 January 2011 - 07:29 PM
Posted 12 January 2011 - 07:39 PM
Can you give more details - does it turn over but slowly, just make a clicking noise, turn over but not fire, or what?
Yeah basically it clicks fast but will not start, also I cannot jump start it off another car but I can bump it.
Posted 12 January 2011 - 07:41 PM
Posted 12 January 2011 - 07:43 PM
Edited by olds_kool_lews, 12 January 2011 - 07:43 PM.
Posted 12 January 2011 - 07:44 PM
sounds like a flat battery
I'm afraid not, I have driven it after starting it by bumping, and then gone to restart it and no joy, also it is a new battery.
Posted 12 January 2011 - 07:45 PM
Should jump start with a duff battery.sounds like a flat battery
Check the connections at the starter motor - may well find a dodgy spade connector lurking.
else you can put power straight to the starter and trigger the solenoid on it with a 'jumper' wire - that would rule out any dodgy earths...
Posted 12 January 2011 - 07:47 PM
Me and my mate tried using a chain of jump leads going from the battery to the starter and it still wouldn't go. What does fubar mean?
Posted 12 January 2011 - 07:49 PM
Posted 12 January 2011 - 07:50 PM
Posted 12 January 2011 - 07:51 PM
A chain? lol - might be easier to put the battery next to the starter... connect the black to the body of the starter and the battery -Me and my mate tried using a chain of jump leads going from the battery to the starter
. Red to the main lug on the starter and the battery +
then you need a jumper wire from the + to the 'start' terminal on the solenoid to activate the solenoid to turn it on!
Posted 12 January 2011 - 07:53 PM
Cool and then if it doesn't start, what is the diagnosis?
Posted 12 January 2011 - 07:55 PM
Posted 12 January 2011 - 07:59 PM
Well as you are putting power straight to the starter - bypassing everything on the car - if it doesnt turn the engine over and still makes funny noises then I'd go for a replacement starter!
