when did you pass your test ?
if you are a youngster you might not be able to tow very much
if your not sure check your license
If you passed your test after the 1st January 1997 you can only tow an unbraked trailer with a maximum authorised mass of 750kg without doing another test
http://www.direct.go...cles/DG_4022564
I haven't got a clue what you can legally tow with a mini, I looked it up, and it started talking about train weight, etc and I didn't have a clue what it meant!
Incorrect -after 1997 you can tow any trailer (braked or unbraked) as long as the overall max gross weight (i.e max permissable weight) is below 3500kg. I have looked in to this as i tow a caravan (not with the Mini
