Trouble Fitting New Distributor.
Posted 08 January 2011 - 03:10 PM
So has anyone got any tricks or tips on how to get in? Have oiled it up and tried wiggling it, not sure how hard to push it in.
Posted 08 January 2011 - 03:58 PM
I am replacing my 45d aldon yellow with a 59d aldon yellow with vacuum advance. The problem is it gets stuck on the way in a few mm before I need to line up the drive by spinning the rotor arm. I cann't see it getting caught on anything, so must be inside the block somewhere.
A 45d is A series and a 59d is A+ right?
I'm sure that's right... anyway, the distributors will have different shaped drive dogs on the end which is why the 59 wont fit into the socket for the 45.
What I did was drift out the pins holding the dog drive ends on each of the distributors and swap them over, then use a hacksaw to chop the spindle down to the correct size. However, I seem to remember that I was putting an 45d into an A+ engine, and I'm not sure whether the same method is possible to put a 59d into an A series block.
Posted 08 January 2011 - 04:24 PM
I think they are the same, they look identical. Just thought their might be a knack to putting it in. I could be mistaken though.
Posted 08 January 2011 - 04:47 PM
Edited by bmcecosse, 08 January 2011 - 04:48 PM.
Posted 08 January 2011 - 04:55 PM
Is your block A series or A+
have you compared both the dizzys ?
or post up a picture of both of the dizzy drives and the block
Posted 08 January 2011 - 05:03 PM
Pictures are on there way
Posted 08 January 2011 - 05:18 PM
Old 45D
New 59D
Side by side comparisons
Block
How far in it goes atm
Posted 08 January 2011 - 06:32 PM
Assuming the dog drive is lined up it should just tap in.
Posted 08 January 2011 - 11:26 PM
Posted 09 January 2011 - 03:05 PM
Problem is that the vacuum advance thing gets stuck on the oil pipe, so I can't spin it round. What should I do?
Doesn't matter which side of the oil pipe I go it still won't fit. Is it possible to take the vacuum advance thing off then put it back on with the dizzy in place?
Posted 09 January 2011 - 03:37 PM
Posted 09 January 2011 - 06:25 PM
