Ive spent a bit of time rebuilding a set of MG sprite/midget twin HS2's, found a correct mini manifold, got the floats at the right angles, and all the linkages sorted. They've got H6 needles in them, and were previously running alright on an A+ 1275. I even went to the trouble of blasting all the linkages/screws/springs and getting them all re-electroplated (was getting some other stuff done at the same time), so they're like brand-new.
I'm putting my 1976 1100 clubman back together, and was wondering if I'd notice much of a performance difference between the factory (and in very good condition HS4) and these HS2's. The motor wont have any other mods, bar a set of LCB extractors and _maybe_ a slightly warmer cam. The reason I'm hesitant to go for the twin HS2's is that I could get a fair sum of money for them here in NZ, and it might be worth it to just sell them... One of the reasons I would consider using them is that I now have the right manifold for them, whereas I'll need to make or purchase another one to use the HS4 witth the LCB's.
What do all the folks out there in mini land think? Would I notice much difference using the HS2's over the HS4?
Cheers for your input
