Sub Amp Help
5 replies to this topic
#1 Dexter
Dexter
  • 118 posts
Posted 07 January 2011 - 08:29 PM
Hello
I have a Vibe Slick Sub And amp..
But for some reason the light that shows the amp is on (Green) goes red.. and my sub stop working..
Please help
Dexter
*EDIT*
Misspelling
Edited by Dexter, 07 January 2011 - 08:37 PM.
#2 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 07 January 2011 - 08:37 PM
Taken from Vibe Slick amp manual:
Red LED = protection mode:
Protection LED Illuminates When Amplifier Is Powered Up
✓ Check for shorts on all speakers wires. (IE no speaker wires should be joined together and no speaker wires should be
touching the cars chassis)
● The amplifier is designed to shut down automatically when the units temperature goes above 80 degrees. If the
amplifier feels very hot then this may be the reason for the amplifier not starting.
● Remove the speaker wires and reset the amplifier. If the Protection LED still comes on then the amplifier is faulty. This
damage may have been caused by either failure to follow these setup guidelines or abuse.
#3 Dexter
Dexter
  • 118 posts
Posted 07 January 2011 - 08:41 PM
Thanks I will have a look tomorrow in the daytime...
I don't know what I'd do without this forum :techsupport:
#4 Carlzilla
Carlzilla
  • 1,907 posts
  • Local Club: Splinters Mini Club
Could also be a poor earth causing the problem.
#5 h4wx1e
h4wx1e
  • 553 posts
  • Local Club: sutton mini club
Posted 07 January 2011 - 08:57 PM
i have a slick powering my subs and the light only goes red when i turn the gains up something stupid, every time theirs a big b-line it flickers between red and green but when turned down its fine. this is my personnel findings im not an expert. by the way both my vibe amps do this until i turn down the gains.
sorry should add as well my head unit turns off too, when i turn it up to loud, might be irrelevent but it might help, kinderish.
Edited by h4wx1e, 07 January 2011 - 09:00 PM.
#6 Dexter
Dexter
  • 118 posts
Posted 08 January 2011 - 11:41 AM
I Fixed it...
The remote was touching the earth
Thanks for the help
Dexter
