Any Difference Between Drum And Disk Driveshafts?
Posted 06 January 2011 - 11:49 PM
Posted 07 January 2011 - 12:20 AM
Hope this helps, someone will come explain it abit better lol
Posted 07 January 2011 - 12:24 AM
Posted 07 January 2011 - 12:52 AM
But there are 3 differant types (4 if you count the 18 spline 1959 to 60 shafts) of shaft. It all depends which inner joints are fitted, rubber couplings, hardy spicers or pot joints.
Posted 07 January 2011 - 12:55 AM
Posted 07 January 2011 - 01:23 AM
There is no differance between drum and disc drive shafts for a particular mark of Mini.
Just a quick note, rubber couplings and hardy spicers use the same shafts.
Your right, my mistake.
Edited by surfblue63, 07 January 2011 - 01:24 AM.
Posted 07 January 2011 - 01:24 AM
Cv joints are interchangeable, but the disk brake shafts themselves are a lot thicker than the skinny drum brakes ones.
That tends to be true only with minis from a certain time period in the eighties. BL's famous cost cutting..........
I fitted a cooper s set up to an 84 previously drum braked mini, the drive shafts were a lot thinner than the disk ones. But the later disk brake CV joins defiantly fitted the skinner shafts.
Posted 07 January 2011 - 07:22 AM
The shafts were different, outer CV's needed changing but the main thing I noticed was the 'ball bearing cage' on the end of the disc shafts did not fit into the inner CV's!
I had to drift the cage from the drum shafts and swap it over. I thought this was a little odd but it worked!
Posted 07 January 2011 - 09:24 AM
Posted 07 January 2011 - 10:33 AM
Do you mean you drifted the bearing cage off of the inner member of the por joint? The star shaped section is part of the joint, not a fixed part of the shaft. If so you now have a real mish-mash CV joint, which is supposed to be a very closely tolleranced component. It would have been a lot easier to change the whole joint properly than to drift off and replace the bearing cage.
Posted 07 January 2011 - 03:36 PM
Posted 07 January 2011 - 10:01 PM
Are the rubber coupling and the later cv joint shafts different or interchangeable?
