52mm Or 50mm Holesaw For 52mm Gauges
5 replies to this topic
#1 danrock101
danrock101
  • 2,478 posts
Posted 05 January 2011 - 08:57 PM
What holesaw should I get for 52mm tim gauges, I've read that you need 50mm is this so? Not sure how the 52mm is measured, if it's the actual dial face and that overlaps the hole slightly
#2 maggies_minder
maggies_minder
    TMFs New official Spamster
  • 4,393 posts
Posted 05 January 2011 - 09:37 PM
this is a free bump as i dont have the answer but im in the same position,
4 52mm TIM gauges to go in a spanking new fibreglass dash, i dont think im brave enough to cut them out myself :thumbsup:
#3 samsfern
samsfern
  • 5,243 posts
Posted 05 January 2011 - 09:42 PM
id go for the 50mm one, you can always file the hole out if its not big enough. Just put the hole saw up against the gauge before you cut, to be sure of size
Edited by samsfern, 05 January 2011 - 09:43 PM.
#4 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 05 January 2011 - 10:08 PM
Cut the hole to a maximum finished diameter of 52mm. The bezel of the 52mm gauges is closer to 56mm.
Hole saws make nasty, rough cuts. Obviously they are necessary sometimes. If you are doing this for only a handful of gauges, a better way would be to cut an undersized hole as Samfern suggests. You can then use a file, sanding drum, or hand powered nibbler to enlarge the hole to an exacting fit with minimal damage to the surrounding area.
I prefer hand powered nibblers for detail work. In the link below you can see the type of tool I'm talking about.
http://www.speedwerx...handnibbler.jpg
or
http://ep.yimg.com/c..._2140_123299525
#5 danrock101
danrock101
  • 2,478 posts
Posted 05 January 2011 - 10:11 PM
cheers guys will order a 50mm one, I'll probably use a die grinder to finish it off I think
#6 In-a-mini
In-a-mini
  • 831 posts
  • Local Club: smag (southend mini action group)
Posted 05 January 2011 - 10:41 PM
If you use a quality hole saw they have a brilliant finish i use DART or Bosch ones no problem they are very acurate.
