Honda B18c Mini
#61
Posted 13 May 2011 - 12:02 PM
#62
Posted 15 May 2011 - 10:14 PM
Im sure that hed be able to chop it around so it fits for you , He should be making me a few bits up l8r in the year like a alloy role cage and catchtank and all the brackets for bits and pieces , like i say he does a excelent job , where abouts is it you are from mate ? hes in drayton near norwich .Damn ive been reading this thread and now you have got me thinking. I was all set to chop up my bulkhead but now you have got me thinking about having this gentleman chopping my skunk 2 instead?
Im in worcester so i would have to post it too him with an angle that I would like it chopped at! Really need to get the frame bought so that I can start measuring up.
Edited by Sleepy Stu, 08 July 2011 - 06:36 PM.
#63
Posted 18 May 2011 - 04:36 PM
#64
Posted 30 May 2011 - 12:43 PM
Good luck tho matey
#65
Posted 30 May 2011 - 12:55 PM
#66
Posted 31 May 2011 - 06:50 PM
Hi yeah the pump will work fine like that , its no different to on any injection carwill that pump work like that in top
#67
Posted 09 June 2011 - 12:37 AM
May I ask, Did the Walbro255 pump just mount right in the tank or was there some modification? Will you have to run a return fuel line? Another question I had was how hard would it be do do the 45* chop on a stock intake manifold? Easier to cut away the firewall?
Best of luck.
#68
Posted 09 June 2011 - 01:59 PM
You need a fuel return line aswell, easiest way is to get some 8mm copper pipe from B&Q and run two lines, feed and return, if you can get some MPI fuel lines then get two of the feed lines as they are about 8mm aswell, but they aint easy to come by - or post!
For the manifold, send it off to be cut/rewelded, unless you can do it yourself, the guy Paul found looks to have done an awesome job, the standard honda intake is not straight so its not easy to cut like this, even the skunk2 is tapered on the outside runners aswell, the one used here is alot straighter to start with. But this is with Pauls frame, if you use another frame or make your own you'll need to find out exactly how many degrees you need, not easy to do
Out of the two - chop the inlet and keep your firewall
Sorry Paul, all yours
Edited by Kam, 09 June 2011 - 02:00 PM.
#69
Posted 11 June 2011 - 02:05 PM
#70
Posted 22 June 2011 - 08:20 PM
#71
Posted 22 June 2011 - 08:48 PM
#72
Posted 22 June 2011 - 09:18 PM
Yeah im hoping a trip to mini in the park should get the motivation back , and give me some more ideasGood to hear your up and well though, don't worry about the motivation thing, it has a bad habit of cropping up again......
#73
Posted 08 July 2011 - 03:34 PM
#74
Posted 08 July 2011 - 07:33 PM
Is the minitec rad different to the tegiwa one you got then? is is just the bottom outlet?
#75
Posted 08 July 2011 - 07:43 PM
