Hi yeah it was very expensive but i think it was well worth it everything fits perfect and nice and easy to fit to the car , it fits the b18 engine easily aswell you just have to elongate a few holes on the olternator bracket and grind a little bit of metal of the lugs on the rocker cover .sorry i just read the mini tec site and have found the answer.
Very expensive aswell!!!
Honda B18c Mini
#31
Posted 13 March 2011 - 05:33 PM
#32
Posted 17 March 2011 - 06:42 PM
#33
Posted 11 April 2011 - 04:54 PM
#34
Posted 11 April 2011 - 07:20 PM
Did you get your DTA from Watsons? If so, then just double check they are all 12v relays and not 24v
Really tidy build, good work, keep at it
#35
Posted 14 April 2011 - 06:36 PM
Edited by paul190181, 14 April 2011 - 06:38 PM.
#36
Posted 14 April 2011 - 08:24 PM
#37
Posted 15 April 2011 - 03:14 PM
Hi no their is no liner in their but its only going to bee a sunny day car so im hoping it should be to big a problem with it .looks great. One thing I always wondered about is the wells. If you've cut them out on both sides for the rad on one side, and the engine on the other, is there some sort of liner that gets replaced? I built a 550 spyder a few years back and we had no rear liners. I would have to clean 3 lbs of rocks and sand out of there every few days.
#38
Posted 15 April 2011 - 03:18 PM
#39
Posted 24 April 2011 - 09:19 PM
I've noticed you've cut away at your front panel a little bit of the manifold and slave cylinder. Do they protrude much? Would they rub on a grill?
Also I've been reading on 16vmini that the 45's for the inlet manifold can collapse in on themselves causing the engine to run rich or not at all. Just a little warning for you. I don't know if you can get reinforced ones or not. Maybe worth a look.
Edited by Bounce, 24 April 2011 - 09:21 PM.
#40
Posted 25 April 2011 - 08:59 AM
Great thread.
Hi no the slave cylinder and inlet doesnt pertrude to far i have tried fiting the grill on and it fits fine the only thing im going to do is get the exhaust wraped and enamel coated to keep th heat down . Yeah id cam to that conclusion on the mini inlet this week end while trial fitting so i decided to cut it in half and get the pipes milled down at 30degrese so they fit flush at a nice angle away from the bulkhead and have them welded together so i dont have any problems with to much air etc .
#41
Posted 25 April 2011 - 10:48 AM
Not sure if you mentioned it, but what are you doing for a fuel pump? I remember reading a couple of years ago that the SPI pump would be OK to use for a B16. Would it do for your B18?
#42
Posted 25 April 2011 - 11:47 AM
#43
Posted 25 April 2011 - 03:38 PM
Nice. Plenty of pictures for your reworked inlet manifold please. It's something I'd be interested in doing when I get my project on the go.
Hi ive got a uprated walburo pump im my mpi tank so it should be more than capable of fuling it and going to fit some new type r injectors so the fuling side definately wont be a problem , il post some inlet pics up when i start on it the machine shops shut down until next week but after that i will hopefuly start making some good progress.
Edited by paul190181, 26 April 2011 - 07:59 PM.
#44
Posted 26 April 2011 - 06:42 PM
If you are intent on using a mini one (I still say a big fat massive NO) then forget the SPI and get a MPI, on the side is some numbers on both
If the pump has 5 numbers followed by 7 numbers then thats a SPI, if its got 8 numbers followed by 5 then its a MPI and what you want
But not really what you want
Paul - 45 hoses have got history, I know there has been a couple of times I've read about them popping off or leaking, not always but has happened, your inlet runners look more straighter than the poxy standard honda tapered ones so if you can get them cut and re-welded it will be better but more work
#45
Posted 26 April 2011 - 08:04 PM
Fueling wise as mentioned already I wouldn't bother with a mini pump, yes some have used a MPI one but to be honest the last thing you want at near 9k revs is lack of fuel! If its gonna be a budget build then fairy muff but even still this is one area I wouldn't bother with taking the risk and just find some more pennies - get the walbro 255 lph and chuck it in the injection tank if your keeping the standard mini tank that is, its got more than enough for what you need and will handle even the most silly of mods you throw on the engine
hi kam yeah allready ditched the 45 elbows , the inlets going into a local machine shop when they open next week to be milled down to a 60 degree angle and welded up , and ive already got a walburo 255 pump in the tank , cheers for the advice on that .
