Stainless Steel
19 replies to this topic
#16 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 29 December 2010 - 07:55 AM
I'm just going to bury my head in the sand a pretend the IVA test doesn't apply to me :)
like i said the battery trays on the camper are non structural my current ones are made from plywood
#17 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 15,962 posts
  • Name: Neil
Posted 29 December 2010 - 11:51 AM
With regards to the Galvanic corrosion or dissimilar metal corrosion there are ways around this but because you have to weld the items together then this is not feasible.
If you were to bolt the items together or rivet (solid rivets ie Monel or Hi Loks etc) then a suitable barrier between the mating surfaces is required. For aviation purposes for example at least one of the surfaces (call it the mild steel side) will need a protective finish on it normally etch primer and a top coat for best protection. The stainless side could also be etched and painted as well but between the two surfaces you would use an interfay layer. This is basically a sealant whose chemical properties prevent Galvanic or dissimilar metal corrosion from starting.
So for a car on a budget its not really a proposition although for non structural areas then there would be nothing to stop you from using stainless.
#18 samsfern
samsfern
  • 5,243 posts
Posted 29 December 2010 - 12:20 PM
nah Bungle , :(
surely you must have realised it'd make your car need an IVA, as the structural areas wouldn't be to the standard factory specifaction! LOL :) :)
:owned: :P
#19 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 29 December 2010 - 01:09 PM
nah Bungle , :(
Possibly the funniest thing I've seen on this forum for a very long time
#20 Cooper-202S
Cooper-202S
  • 201 posts
Posted 30 December 2010 - 05:55 PM
Who wants to be the 1st to phone BMH and ask for a price on a complete set of panels in stainless then?
Has got to be worth the chuckle.
