is it possible to fit the new tee piece where I just fitted that sender, then fit the sender I just fitted onto the new tee piece? so they both come off the same hole? or does the tee piece not allow this?
Jason
Thats exactly what the T piece does (allows the oil light on the dash AND an oil pressure gauge.)
Remove original sender
Screw T piece into block.
The sender then goes into the end of the T piece.
There is a small adapter that screws into the side of the T piece
Oil pressure pipe screws onto the adapter, then goes to the back of the gauge in the car
T Piece (bottom hole = original sender. Side hole = adapter
Thread adapterPipe (5')
Edited by L400RAS, 30 December 2010 - 09:36 AM.
