Oil Light Still On Even Though Its Got Oil In It?
#16
Posted 28 December 2010 - 11:42 AM
it is only on dull though - not like it is normally when the key is normally in position 2 and both lights are on...
I am going to change the sender - will have to wait till tomorrow...
Will keep everyone informed...
Thanks for all the comments so far!
J
#17
Posted 28 December 2010 - 01:55 PM
#18
Posted 28 December 2010 - 01:57 PM
#19
Posted 28 December 2010 - 02:32 PM
If it did not show any pressure, then pull the engine out and take it off the box.
There is nothing like a proper pressure gauge with a Mini for confidence.
#20
Posted 28 December 2010 - 03:19 PM
The light is not at full capacity at all now, whether the engine is started or not...
I really hope its just the sender, I will get one tomorrow and take it from there...
if its not... and the engine needs to be removed... is it worth having the work done on it? or getting a new engine for it? (its currently an SPI 1275, but its lacking power so I was saving up for some work to be done on it anyway... but is it worth spending money on an spi engine to gain more power? given that it might have more problems?)
Jason
#21
Posted 28 December 2010 - 03:23 PM
I hope it's just a faulty pressure sensor for you mate!
me too!
J
#22
Posted 28 December 2010 - 03:24 PM
#23
Posted 28 December 2010 - 03:28 PM
pull the wire of the switch . is the oil light still lit up ???
from the sender?
...the oil light goes out when I disconnect it from the sender (switch?)
J
#24
Posted 28 December 2010 - 03:29 PM
#25
Posted 28 December 2010 - 03:39 PM
from the sender?
J
What happens if you earth the wire? Does the light come on bright?
#26
Posted 28 December 2010 - 03:51 PM
If you get stuck I think there is a sender on one of the spare engines in the shed, but try and get a new one as I don't know if they work ok or are just blanking the hole.
If it turns out just to be the switch, it's worth fitting an oil pressure gauge instead of your oil temp gauge, it isn't too difficult to do.
Edited by Kerrin, 28 December 2010 - 03:52 PM.
#27
Posted 29 December 2010 - 01:04 PM
No luck with Express factors then? I guess they are all closed till tommorrow.
I have called round - no luck as yet, waiting for a few to call me back while they search for one...
will have to see when they get back to me.
Failing that, I might get one ordered and send special delivery and hope it gets here tomorrow...
I have an engine temperature gauge on my car anyway... so doing without the oil temperature gauge wouldn't be the end of the world would it?
J
p.s. I have not tried earthing the cable yet - will try that later on...
Thanks all, will keep progress posted!
#28
Posted 29 December 2010 - 02:48 PM
If so just get a matching oil pressure gauge from minispares and swap them. The oil pressure is straightforward to fit but will need a few plumbing parts to connect it to the engine.
#29
Posted 29 December 2010 - 04:06 PM
If I recall you have an mpi dash with an oil temp gauge that isn't connected.
ok, I will sort the oil pressure gauge out
as for the sender, DMS have one (I dont normally like getting from DMS cause ive heard the parts are a bit inferior... but will give them a whirl!) I have got someone to ick it up for me and I will get it from them later on when I have a lift to douglas!
£4.38 inc VAT - HOPEFULLY that'll fix it!
Will try to fit it later on and see how it goes.
J
#30
Posted 29 December 2010 - 04:21 PM
In 25 years of buying car bits, I have never successfully got them to order me anything.
Good luck with it but I think it will sort the problem.
