Another Micra Mini
225 replies to this topic
#121 charie t
charie t
  • 3,153 posts
Posted 04 May 2011 - 10:43 PM
Does anyone know where I can get my CO2 bottles exchanged in the Newark/Lincoln area ??
What bottle?
#122 benbob
benbob
  • 25 posts
Posted 05 May 2011 - 03:42 PM
What bottle?
It's about 2ft high and grey (I think it holds about 5kg of CO2 when full)
#123 ibrooks
ibrooks
  • 1,017 posts
Posted 06 May 2011 - 10:48 AM
Sounds like it mght be a pub bottle. I get CO2 from a local bottled gas place that supplies pubs but if you know a friendly landlord you might be able to come to an arrangement with them. I paid a £25 deposit for the bottle and it costs £20 to get it swapped for a new bottle (only had to do that once in 2 years though).
Iain
#124 rids
rids
  • 670 posts
Posted 06 May 2011 - 06:45 PM
Dimensions of inlet manifold as requested.
#125 rids
rids
  • 670 posts
Posted 16 May 2011 - 04:15 PM
does anyone know what vacuum pipes i need and where they go on micra inlet? i have to drill my new manifold to fit vacuum pipes i'm not using the carbon filter.
#126 Artstu
Artstu
  • 830 posts
Posted 16 May 2011 - 04:40 PM
There are 4 on the standard manifold,
Small one for the fuel pressure regulator
Large one for the cam cover breather
Large for the servo
and the small one for the carbon/charcoal can
#127 rids
rids
  • 670 posts
Posted 16 May 2011 - 04:44 PM
i should only need the one for the fuel regulator then. why do you need a vacuum feed to the cam cover?
#128 Artstu
Artstu
  • 830 posts
Posted 16 May 2011 - 04:48 PM
Yes just that one will do. The cam cover breathes into the inlet manifold, standard Mini's do the same into the carb, one reason the bottom of the manifold is usually full of oil
#129 rids
rids
  • 670 posts
Posted 16 May 2011 - 06:07 PM
can i use this one for fuel regulator?
Also do i need to connect these? they are next to temp gauge on side of block sort of under the dizzy. if so where to?
#130 Artstu
Artstu
  • 830 posts
Posted 16 May 2011 - 07:17 PM
That pipe above the throttle butterfly is used to open the carbon can, however at closed throttle it isn't going to present the same vacuum it would see in its original position on the manifold so the fuel regulator I'm guessing won't behave in exactly the right way. Perhaps someone else can confirm and explain the effects better than me.
Not sure about the other photo, mine only has electrical connections at that point.
#131 rids
rids
  • 670 posts
Posted 16 May 2011 - 07:26 PM
the ones in the dark photo i suspect have something to do with water temp as they are right next to the temp sender. i also have a feeling they have something to do with carbon filter
#132 Artstu
Artstu
  • 830 posts
Posted 16 May 2011 - 08:07 PM
right, the single connector one is for a temp gauge and the one with 2 pins is a temperature sensor talking to the ECU
#133 rids
rids
  • 670 posts
Posted 16 May 2011 - 08:12 PM
that explains the electrical connectors but not the vacuum hose connectors there
#134 Artstu
Artstu
  • 830 posts
Posted 16 May 2011 - 08:26 PM
So have you got two sensors there and the vacuum hose connector too, mine only has the two sensors
#135 rids
rids
  • 670 posts
Posted 16 May 2011 - 09:22 PM
i have! if i blow thru 1 it comes straight out the other i cant remember where pipes went when i pulled the engine out!
