Another Micra Mini
225 replies to this topic
#16 rids
rids
  • 670 posts
Posted 31 December 2010 - 04:07 PM
ive seen ians wiring diagram and hope to follow it. i'd like to keep injection but dont want to cut bulkhead. looking into fabricating/ modifing a new inlet manifold that fits better. the wiring does scare me a bit! much prefer working with nuts and bolts
#17 rids
rids
  • 670 posts
Posted 06 January 2011 - 08:39 PM
Started on subframe today, got it roughed out and started to make side rails. looks to get very tight on water pump to suspension tower!
Rest of the car is coming on well.
Edited by rids, 21 January 2011 - 05:38 PM.
#18 evansisgreat
evansisgreat
  • 1,103 posts
  • Local Club: Not yet
Posted 06 January 2011 - 08:52 PM
Looking good mate. Loooove the colour!
Just a thought, will that plate between the the floor mounts get in the way of the gear linkage? Hope not, looks to be a good way to strengthening.
#19 rids
rids
  • 670 posts
Posted 06 January 2011 - 09:49 PM
i hope not but i'll not know for definite till i trial fit subframe in car. if it does i'll cut as little as possible away to keep as much strength as i can. plan is to get engine fitted where i want it , trial fit subframe in car them seam weld as much as possible and add ribs/webs etc before final fit. i fancy trying to keep the alternator at the front if possible even if it means cutting inner wings a bit
#20 rids
rids
  • 670 posts
Posted 08 January 2011 - 04:03 PM
cars been painted today! green.
Edited by rids, 21 January 2011 - 05:30 PM.
#21 rids
rids
  • 670 posts
Posted 08 January 2011 - 04:09 PM
some progress on subframe today, got enough room for engine now.
nearside driveshaft is very tight and inner cup dosnt fit through subframe! any suggestions would be greatly appreciated.
Edited by rids, 21 January 2011 - 05:32 PM.
#22 charie t
charie t
  • 3,153 posts
Posted 08 January 2011 - 04:53 PM
Is that on some kind of jig? Its not going to have much ground clearance if its not
#23 rids
rids
  • 670 posts
Posted 08 January 2011 - 05:01 PM
all the 2 inch angle is temporary. it makes it a bit easy to work on and kept the dimensions right till the sides are finished
#24 charie t
charie t
  • 3,153 posts
Posted 09 January 2011 - 03:11 PM
I would check it fits in the car before you get too far along
#25 whyter
whyter
  • 34 posts
  • Local Club: IMOC
Posted 09 January 2011 - 06:45 PM
Defo check it fits, i think you ve cut a bit much away for the diff, it will hit the steerin rack. looks good though paint is cool, Came out of my igloo in ireland the other day, so hopin to get stuck in again, i was in england for the weekend and bought a 1300 engine from a man who rallies a micras, so lookin forward to gettin it running
#26 rids
rids
  • 670 posts
Posted 09 January 2011 - 06:56 PM
the subby fits if i trim the base of inner wings a bit. as for hitting the rack i thought the position of the driveshaft hole determined how far back the motor sits. to be honest it looks tight everywhere! they must be a real snug fit when they are in.
#27 charie t
charie t
  • 3,153 posts
Posted 09 January 2011 - 07:04 PM
Not really, think you'll find that hits bulkhead or the rack or both, best to try
#28 rids
rids
  • 670 posts
Posted 09 January 2011 - 07:09 PM
looking through the driveshaft hole how much further forward do you think it should go? ive got it fairly central
#29 charie t
charie t
  • 3,153 posts
Posted 09 January 2011 - 07:17 PM
so the diff clears the rack/bulkhead, might have to run it on the angle slightly. may have to pul it forward 3/4" or so
#30 rids
rids
  • 670 posts
Posted 09 January 2011 - 07:22 PM
ok cheers i'll try and cut driveshaft hole as bigchiefs this week and see if i can pull motor forward a bit.
