Another Micra Mini
225 replies to this topic
#211 rids
rids
  • 670 posts
Posted 25 July 2012 - 08:43 PM
I'll try and take some pics at weekend. if you use a side mounted rad, the hose routes just fall into place. I used standard rad, turned upside down with the filler neck welded up. then an expansion tank nose added to "new top" no overherating issues at all.
#212 l_jonez
l_jonez
  • 1,453 posts
Posted 25 July 2012 - 09:42 PM
Might be worth looking at fitting a front mounted rad, I did and its no harder to fit.
#213 rids
rids
  • 670 posts
Posted 26 July 2012 - 06:37 PM
i've had no cooling issues with this set up, the fan has never come on as it runs under 1/2 on the gauge in all conditions
#214 l_jonez
l_jonez
  • 1,453 posts
Posted 26 July 2012 - 10:52 PM
Same here no issues at all just saying that it might be easier to fit a front rad than altering a mini rad.
Personaly I don't like the fact that the nissan ecu dosent operate the fan till 98 degrees I've set mine to 90 which is 2 more after the thermostat opens.
#215 charie t
charie t
  • 3,153 posts
Posted 29 July 2012 - 05:00 PM
Why not?
#216 l_jonez
l_jonez
  • 1,453 posts
Posted 29 July 2012 - 09:54 PM
Just that most manufacturers stick to the low 90's. 88 degrees is the optimum temprature for unleaded petrol, seems pointless letting it heating up any more than that.
#217 charie t
charie t
  • 3,153 posts
Posted 02 August 2012 - 08:36 PM
Its only the fan that comes on at that temp. The only times its likely to come on is in traffic when optimum isn't really relavant
#218 Mini_Matt
Mini_Matt
  • 96 posts
Posted 27 September 2012 - 12:34 PM
This is a great build mate....Finished to a high standard too.
do you reckon my brother will notice if I take the engine out his micra. lol
#219 rids
rids
  • 670 posts
Posted 21 December 2012 - 03:55 PM
Its been a while, havn't tinkered at all this year its been that reliable, however I have got round to mounting radiator and fan properly.
#220 Artstu
Artstu
  • 830 posts
Posted 21 December 2012 - 06:06 PM
Looking good. I'm pleased you didn't sell it, hopefully you are too.
#221 rids
rids
  • 670 posts
Posted 21 December 2012 - 06:09 PM
I am..., puts a smile on my face every time i drive it
#222 AndrewMini
AndrewMini
  • 154 posts
Posted 27 February 2013 - 08:59 PM
nice project,same sort of colour scheme im going for! im looking to put a micra engine in mine soon, are there any big problems you can warn me of? does the gear stick come out in roughly the same place as a mini or will something have to be fabricated to hold it?
#223 rids
rids
  • 670 posts
Posted 28 February 2013 - 05:39 PM
the gearstick comes out the same hole as mini one. I elongated the two 8mm rubber mount holes by 1/2 hole each and micra assembly slotted right in.
Any problems you might have can be overcome by various methods covered in the build threads on this forum.
#224 Hugh Jorgan
Hugh Jorgan
  • 20 posts
Posted 29 March 2013 - 11:05 PM
Nice job rids,,, looks real nice & thank you for posting your conversion , it`s obviously helped out a whole lot of people to do their own, good on you
& Fuzzyhair,,, i`m thinkinbg of doing this conversion too, where abouts in Aus are you? I`m in Brisbania
#225 fuzzy-hair-man
fuzzy-hair-man
  • 181 posts
  • Local Club: Minis in the Gong
Posted 30 March 2013 - 01:22 AM
The mini is in Armidale NSW, but I'm based about 700km away in Moss Vale, hence the slow pace of my conversion... :(
The engineer I'm using is in Ballina so wouldn't be far from Brissy, (the engineering process is national now, so he may be able to help though he doesn't know mini's much so there's probably better Brissy based options) if you look on ausmini there are a few mini conversion happening up there, Matt Read who runs a mini business is looking to do a micra conversion so he would probably have some advice, other than that there are very few micra conversions in Aus, they all seem to go for 4EFTE conversions of suzuki swifts.... not sure why they just all seem to want silly amounts of power.
Happy to help with any advice, speak to your engineer early, and buy a whole Micra there's no point stuffing around with just bits...
The Australian K11 micra forum have been really helpful, www.micra.com.au
