Another Micra Mini
225 replies to this topic
#181 Tayzore
Tayzore
  • 35 posts
  • Local Club: British mini club
Posted 14 October 2011 - 09:12 AM
Good build mate, makes me want to start my own project.
you got any rough ideas on overall spend?
#182 rids
rids
  • 670 posts
Posted 14 October 2011 - 03:13 PM
thanks for all the positive comments.
as for price, off the top of my head, write off micra £250ish, subframe material £60, manifolds about £350, wiring £200, driveshafts £60, ive forgot the rest, sold my 1293 engine carbs and lcb for £390 so all in about £530.00.
#183 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 14 October 2011 - 04:25 PM
i may want to come look at your subframe in the future, as i plan to do this conversion unless i find a different engine which ticks the boxes.
#184 rids
rids
  • 670 posts
Posted 14 October 2011 - 04:56 PM
no problem, come and have a go see what you think...I'm in tynemouth mini club too.
#185 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 14 October 2011 - 05:01 PM
yeah stevie my mate told me, hes got the dark red clubman estate. I dont get along to the tynemouth meets these days, but may start coming along again as im getting the bug back.
#186 rids
rids
  • 670 posts
Posted 14 October 2011 - 05:11 PM
oky doke pm me for a drive
#187 fuzzy-hair-man
fuzzy-hair-man
  • 181 posts
  • Local Club: Minis in the Gong
Posted 14 January 2012 - 04:30 AM
Hi Rids,
Just wondering there is a Reed switch (magnetically actuated switch) on the back of the Micra speedo (the two little screws) that provides a speed signal to the ECU. Have you got these connected?
The bit of reading I've done on the ECU speed sensors says that they provide an input allowing the ECU to know when to turn on or off things like a cold start circuit and idle speed control, I just remembered that you were having a bit of trouble with yours when it was cold and I was wondering if this might have been contributing to the issue?
The way I figure either the ECU knows it hasn't got a speed sensor so it may not know when to do idle control stuff so it might abandon it completely giving a bad idle or it might still think it's there and no signal means that it's stopped and activate the idle stuff any time your off throttle...
The bit I found explaining it is here:
http://www.autoshop1...m/forms/h26.pdf (page 11)
Other conversions don't use the Micra speedo at all so presumably the ECU not getting a speed signal isn't a huge deal but if you've got the Micra speedo in there anyway I guess it's worthwhile hooking up right?
Anyone know if that's the only ECU sensor that exists outside of the engine loom?
#188 rids
rids
  • 670 posts
Posted 14 January 2012 - 10:05 AM
As i only used the speedo head i discarded all the electrics behind it anyway so it's too late to give it a try. I was probably being a bit fussy because its not really that bad. Its never stopped me driving it. Ive just finished a standard mini 1275 for myself and my son to use and driving that reminds me how refined the micra conversion makes a mini feel.
#189 fuzzy-hair-man
fuzzy-hair-man
  • 181 posts
Posted 14 January 2012 - 10:27 AM
One of the wires goes to earth according to my wiring diagram the other plugs into the ECU so as long as you could identify the correct contact in the plug it should still be do-able.
I've been meaning to ask was there anything you did to the Micra speedo to get it as accurate as you did? the range of motion for the speedo needle seems similar but the Micra speedo is 200km and the Mini 90 miles or approx 150 km / hr shouldn't that leave the speedo out by about a third? or am I missing something? I want to use 10 inch wheels but I still can't see it making up the difference...
I might see how accurate or inaccurate it is and work things from there, it's a long way down the track anyway. I've learnt a lot reading your build, Thanks
#190 l_jonez
l_jonez
  • 1,453 posts
Posted 14 January 2012 - 10:48 AM
On the early center clocks they where matched to the fd, there's a little number on the face. If your using a center clock its just a case of working out the ratio and finding the closest clock. As for the 2/3 clock type either contact the likes of speedy cables and the can alter the clocks or just drive around with sat nav then make a new clock face.
#191 rids
rids
  • 670 posts
Posted 14 January 2012 - 05:47 PM
The accuracy was just luck, its the complete micra head behind the mini centre clock front, if you look carefully you can see the milage numbers are slightly different to mini ones, on another note, i couldn't help fitting these.
#192 Artstu
Artstu
  • 832 posts
Posted 14 January 2012 - 07:55 PM
Did you notice any difference with the Metro brakes aside from the increase in track?
#193 rids
rids
  • 670 posts
Posted 14 January 2012 - 08:17 PM
never drove it enough yet..it's currently sorned till the gritters go away, the pedal feels softer tho, Is the track wider, the wheels looks the same under the arches
#194 Artstu
Artstu
  • 832 posts
Posted 14 January 2012 - 08:21 PM
I think the track increase is around 8 mm a side.
#195 lucas1amps
lucas1amps
  • Just Joined
  • 587 posts
  • Local Club: Weston Mini Muckers
Posted 23 January 2012 - 11:37 PM
great build im planning on doing the convertion myself cant wait =]
