Another Micra Mini
225 replies to this topic
#151 bigchief3679
bigchief3679
  • 228 posts
  • Local Club: trinimini
Posted 11 July 2011 - 02:33 AM
Awesome green machine!
The throttlebody mod looks seamless. Are you having any cooling issues? Reason i ask is your fan, shouldn't there be a shroud along its circumference to force air through the rad? Also, the skew of the blades suggest that it is designed to run the other way, running it this way may cause it to be noisy/turbulent and a little inefficient.
Also, luvs the upside-down rad!!! :thumbsup:
#152 rids
rids
  • 670 posts
Posted 11 July 2011 - 01:43 PM
no problem at all with cooling. the fan switch is wired thru the ecu and has never came on yet. i do have an overide switch wired in but again, never had to use it. To be honest i rushed mounting the fan to get it on the road with the plan of improving it in the winter.Ive done prob 500 miles in it now and the only snag ive had is lambda sensor positioning, the car ran great cold but as it got warm it was like running on choke, i removed lambda and had it resting in engine bay and the car ran near perfect like that, ive since looked at original mount and not much of the sensor was sitting in the gas flow,( the boss i made was to long!) ive now shortened the boss so more of the sensor sits in the exhaust. The car pulls really strong with this motor and if i'm really criticle, i'd say it could do with a higher final drive, its accelleration is great, but top speed seems to be about 90 on the sat nav without killing it.It cruises at 70-80 effortlessly and quietly. All told to get this power out of an a series engine would have cost a lot more, and reliability would become an issue. Its a pleasure to drive and has been well worth the effort
Edited by rids, 11 July 2011 - 02:08 PM.
#153 l_jonez
l_jonez
  • 1,453 posts
Posted 16 July 2011 - 07:25 PM
Did you sort the running issues after ?
#154 rids
rids
  • 670 posts
Posted 16 July 2011 - 09:15 PM
I sort of have, after sorting o2 sensor it was running really well, apart from if I switch off when warm, then switch back on it ticks over but bogs down when revved throwing a bit of black smoke out the back. once driven it was fine again, Like I've said wiring is not my strong point and its the only part of this conversion I farmed out. I suspected the coolant sensor wasnt sending signal to ecu, so I tried joining wires at sensor together and it made no difference sort of confirming what i thought. I then disconnected wiring at throttle body end (the connector below the alloy plate covering circuit board) I think this puts ecu into a default mode reading an average coolant temp. This cured fault and car is running really well. however i do want to re connect this so will be tracing coolant sensor wiring back to ecu. It sounds worse than it is, and I may now just being a bit fussy.
#155 l_jonez
l_jonez
  • 1,453 posts
Posted 17 July 2011 - 06:00 PM
the connector on the throttle body is the idle air control valve, i've read its known for them to play up and cleaning them can solve things :)
just re-read some of your build, and with reference to the rocker cover breather, you should connect it to the manifold and then put a small breather/filter on the open end ( next to the dizzy) to stop dust etc being dragged in
#156 rids
rids
  • 670 posts
Posted 17 July 2011 - 06:46 PM
i can get a flat, pancake filter in,(when i source one,) The finalising of project will be very much done as i drive it throughout summer,
as ive said its running really well now and the finalising will be done as i drive it. Its the throttle potentiometer i have disconnected at the minute not the idle valve and it's running spot on I'll keep tinkering forever probably. you are right, i need to sort breathers out, i also fancy an intake tube to draw cool air in from behind grill and i need to tidy fan area up. All advice is greatly appreciated
Edited by rids, 17 July 2011 - 06:53 PM.
#157 l_jonez
l_jonez
  • 1,453 posts
Posted 17 July 2011 - 09:03 PM
Ah sorry misread your post regarding the TB connector. Disconnecting the throttle position sensor should cause problems rather than solve things :)
The one big problem known with micra's is the circuit board on the TB. There's several guides online on how to resolder the board.
#158 rids
rids
  • 670 posts
Posted 17 July 2011 - 10:49 PM
This connector is the one that i'm running without,It seems to act as a choke.. connected choke on, disconnected choke off
http://www.micra.com...orums/37920.jpg
Edited by rids, 17 July 2011 - 10:52 PM.
#159 jimbob69
jimbob69
  • 30 posts
Posted 18 July 2011 - 12:09 PM
Lookin good, i like the idler pulley and alternator adjuster all in one bracket, clever stuff.
What car is the exhaust 4 branch manifold off?
I know folk use k series but there seems to be loads of different ones!
Jim
#160 rids
rids
  • 670 posts
Posted 18 July 2011 - 06:18 PM
Its off a k11 micra then cut and modded to fit mini
#161 Ace Alex
Ace Alex
    Formally known as Pedal Pusher
  • 330 posts
Posted 06 August 2011 - 08:25 PM
Just noticed this build topic! I was looking around your Mini at the Geordie Job. It's very nice with engine conversion and bright colour scheme! :thumbsup:
#162 rids
rids
  • 670 posts
Posted 06 August 2011 - 09:01 PM
thank you, did we speak? what were you driving?
#163 Ace Alex
Ace Alex
  • 330 posts
Posted 06 August 2011 - 09:31 PM
I had two Mini's at the show, my Rover Mini 40 and blue Austin Mini Pickup. I was sitting in the Pickup as you were leaving the show field.
Alex
#164 rids
rids
  • 670 posts
Posted 06 August 2011 - 09:39 PM
i think we chatted at corbridge.....
#165 Ace Alex
Ace Alex
  • 330 posts
Posted 07 August 2011 - 07:45 AM
I never went to that show. That could be the guy from the Tynemouth mini club with the other Mini 40.
Alex.
