Another Micra Mini
225 replies to this topic
#136 rids
rids
  • 670 posts
Posted 18 May 2011 - 05:20 PM
Heres a daft question! is the vacuum operated fuel regulater on the inlet or return line of the fuel rail? ive plumbed it on the inlet line, just want to double check.
#137 Artstu
Artstu
  • 830 posts
Posted 18 May 2011 - 06:21 PM
On the return :shifty:
#138 rids
rids
  • 670 posts
Posted 18 May 2011 - 07:46 PM
i'll swap it back then!
#139 apjmini
apjmini
  • 78 posts
  • Local Club: Not Yet
Posted 23 May 2011 - 07:59 PM
Rids,
I see in your build you mention reinforcing your rubber wheel arches. I just bought a set for my mini this weekend and noticed they were a little wobbly so I read with interest your comments.
Any suggestions/photos of how you went about it ?
#140 rids
rids
  • 670 posts
Posted 23 May 2011 - 08:53 PM
i covered area with masking tape fitted them with masking tape over body to arch join. then with builders squirty foam, built up insides bit by bit allowing each coat to expand and dry. once fully dry i cut back the excess and shaped. i am planning to cover inside of arches with black underbody shultz before i put car on the road
Edited by rids, 23 May 2011 - 08:55 PM.
#141 apjmini
apjmini
  • 78 posts
Posted 24 May 2011 - 07:08 PM
Ok did the expanding foam stick ok to the inside of the arch ?
#142 apjmini
apjmini
  • 78 posts
Posted 24 May 2011 - 07:28 PM
Also meant to ask how's the work going with the inlet manifold ?
#143 rids
rids
  • 670 posts
Posted 24 May 2011 - 08:12 PM
the manifolds finished and on. i hope to have wiring finished within a fortnight and then it should run.
just the normal things to do after that hopefully, bleed brakes, fit bonnet, grill, front indicators, fit interior mot and tax!
#144 apjmini
apjmini
  • 78 posts
Posted 25 May 2011 - 08:41 PM
Good news well done.
Are you painting your arches ?
Mine are black but have a few scratches on them so I need to spray them, so I am looking for the right primer and paint.
#145 rids
rids
  • 670 posts
Posted 25 May 2011 - 09:27 PM
mine are a gloss black rubber so i'm not gonna paint them. once ive got car on road and stopped spending cash on engine conversion i'm gonna look out for some genuine sportspacks
#146 rids
rids
  • 670 posts
Posted 13 June 2011 - 06:57 PM
It runs! although its hunting a bit on tickover, i think it's running a bit rich and needs a run. I had a quick run on private land and everything feels well. i'm not happy with throttle cable run it feels a bit rough, i need a rethink on cable routing. Ive havn't connected cold start pipework, just jammed it in the warm running position for now.
MOT Next!
Edited by rids, 13 June 2011 - 07:05 PM.
#147 James_1
James_1
  • 253 posts
Posted 14 June 2011 - 05:48 PM
Ruddy brilliant job!!! That looks fantastic :). Out of interest, is there space for a filter or have you just left it off till you find one?
#148 rids
rids
  • 670 posts
Posted 14 June 2011 - 07:44 PM
i can get a flat, pancake filter in,(when i source one,) The finalising of project will be very much done as i drive it throughout summer,
#149 rids
rids
  • 670 posts
Posted 15 June 2011 - 06:18 PM
got a longer cable for throttle, its a brake cable off a racing bike nice and long so no tight turns and it's nice and smooth. took it for an mot and passed 1st time.
done about 40 miles in it and am pleased with it. No problems and drives really well. Taxed end of the month and hopefully off to corbridge classic car show on 3rd july. anyone local going?
#150 rids
rids
  • 670 posts
Posted 20 June 2011 - 07:18 PM
air filter on
car all waxoiled and sealed ready for tax 1st july...... roll on!
Edited by rids, 20 June 2011 - 07:31 PM.
