Classic Mini Spares
4780 replies to this topic
#4756 venkman
venkman
  • 497 posts
Posted 11 May 2020 - 10:12 AM
91" Cooper last on carbs
Thanks Ian
Hi can you help with the following,
2 way banjo and bolt for flexible brake pipe on front sub.
Door glass support rails and rubber(pair).
Engine steady bar for bottom of engine to front of front sub.
Pedal box bracket? Has 4 studs that bolts through bulkhead and holds brake servo in place.
Half a dozen nuts for rear brake hoses.
Hope it makes sense
Thanks Ian
Hi Ian,
Yes, what year mini is it for?
Thanks.
#4757 MiniJosh92
MiniJosh92
  • 1,713 posts
Posted 11 May 2020 - 04:17 PM
Hi
I need a pair of black front seatbelts for 1990 Mini please.
I have a pair but they are sun bleached so the blacker the better.
I don’t need the stalks but bolts and plastic covers would be good.
Jason
Hi Jason,
Okay I will check that I have a nice pair tomorrow and get back to you.
Cheers, Josh.
I have a couple of sets but, neither I would describe as mint or not faded at all.
#4758 MiniJosh92
MiniJosh92
  • 1,713 posts
Posted 11 May 2020 - 04:18 PM
Thanks Ian
Hope it makes sense
Thanks Ian
Hi Ian,
Thanks.
Okay Ian no problem. Only one I am not quite sure on is when you say the pedal box bracket, do you need the actual pedal box frame itself or the bracket that sits over the studs on the engine bay side of the bulkhead?
#4759 venkman
venkman
  • 497 posts
Posted 11 May 2020 - 05:03 PM
The pedal box bracket.The clutch and brake pedal pivot underneath it inside car.
#4760 venkman
venkman
  • 497 posts
Posted 11 May 2020 - 05:05 PM
Thanks Ian
Hope it makes sense
Thanks Ian
Hi Ian,
Thanks.
Also just to be a pain can you find a couple of nuts that go on the front rubber hoses, their slim ones .
Thanks Ian
#4761 MiniJosh92
MiniJosh92
  • 1,713 posts
Posted 12 May 2020 - 07:00 AM
Thanks Ian
Hope it makes sense
Thanks Ian
Hi Ian,
Thanks.
Thanks Ian
Will message you
#4762 venkman
venkman
  • 497 posts
Posted 21 May 2020 - 03:43 PM
Thanks Ian
Hope it makes sense
Thanks Ian
Hi Ian,
Thanks.
Thanks Ian
Will message you
Hello Josh,
Forgot to let you know, all parts came Tuesday morning , thanks very much!
Ian
#4763 Rhys
Rhys
  • 898 posts
Posted 24 May 2020 - 06:36 PM
Do you have front hubs for disc brakes?
#4764 owenlcr
owenlcr
  • Just Joined
  • 65 posts
Posted 25 May 2020 - 06:07 AM
Do you have a mini van head lining wire frame available?
#4765 MiniJosh92
MiniJosh92
  • 1,713 posts
Posted 25 May 2020 - 09:36 AM
Yes, will drop you a message
I'm afraid not at the moment
#4766 owenlcr
owenlcr
  • Just Joined
  • 65 posts
Posted 25 May 2020 - 06:42 PM
How about a set of 10" steel cooper S wheels 4.5" width?
#4767 MiniJosh92
MiniJosh92
  • 1,713 posts
Posted 26 May 2020 - 07:10 AM
I'm afraid not a set at the moment.
#4768 owenlcr
owenlcr
  • Just Joined
  • 65 posts
Posted 26 May 2020 - 07:30 AM
Even 2 wheels would be good
#4769 MiniJosh92
MiniJosh92
  • 1,713 posts
Posted 26 May 2020 - 02:09 PM
I do have a pair, will message you.
#4770 owenlcr
owenlcr
  • Just Joined
  • 65 posts
Posted 30 May 2020 - 04:05 PM
Josh, would you have a mk1 bonnet catch available
