yep just the motor
Classic Mini Spares
#4411
Posted 30 March 2016 - 05:54 AM
#4412
Posted 30 March 2016 - 08:29 PM
HI Josh
do you have:
- mark 1 austin bonnet badge with chrome surround like this one, http://www.minispare...|Back to search
Passenger sun visor - I have drivers in black/cream but I need a pair so if you have one, or a pair
clubman bonnet catch guide plate (the bit that goes on the body above the grill)
clubman bonnet prop
heater switch (the one with the yellow light if possible, but I can reuse my switch cap if not)
thanks in advance UT (shaun)
#4413
Posted 30 March 2016 - 09:53 PM
HI Josh
do you have:
clubman bonnet prop
Hi Shaun,
I will check on the mk1 badge but, don't think I have any at the moment.
I have sun visors, clubman bonnet guide plate and bonnet prop.
Not quite sure what you mean about the heater switch with a yellow light?
Cheers, Josh.
#4414
Posted 30 March 2016 - 09:59 PM
sorry josh - i should have been specific. it is the heater switch with the little yellow square lens, rather than the later ones which I believe had blue lenses, but I could be wrong. Any standard heater switch would do though
HI Josh
do you have:
clubman bonnet prop
Hi Shaun,
Cheers, Josh.
I also need the large diameter Heater Air Feed pipe - this is the interior pipe that goes from the drivers side inner wing panel to the heater box over the driver's feet, mine split - if you have one
thanks, Shaun
Edited by Ubertech_s, 01 April 2016 - 10:27 AM.
#4415
Posted 31 March 2016 - 09:30 PM
HI Josh
do you have:
clubman bonnet prop
Hi Shaun,
Cheers, Josh.
thanks, Shaun
I have to say I have never seen a heater switch with any colour on them, always just plain black as far as I am aware like this - http://minispares.co...|Back to search
#4416
Posted 01 April 2016 - 07:09 AM
HI Josh
do you have:
clubman bonnet prop
Hi Shaun,
Cheers, Josh.
thanks, Shaun
oh I am so thick! If I wasnt I would have said "rear screen heater switch" in the first place - sorry Josh, thanks for clearing it up, no wonder you were confused. If you have a rear screen heater switch that has a yellow lens then ;)
#4417
Posted 01 April 2016 - 11:48 AM
HI Josh
do you have:
clubman bonnet prop
Hi Shaun,
Cheers, Josh.
thanks, Shaun
Ah that makes a lot more sense! Okay, I will go through the box of switches and see what I can find.
#4418
Posted 01 April 2016 - 05:56 PM
HI Josh
do you have:
clubman bonnet prop
Hi Shaun,
Cheers, Josh.
thanks, Shaun
I do indeed have one orange/yellow one and loads of green ones.
#4419
Posted 04 April 2016 - 12:37 PM
Hi Josh,
Do you have a set of door hinges for the drivers side door?
#4420
Posted 04 April 2016 - 01:00 PM
Hi Josh,
Hi, yes I do indeed, will pm you.
#4421
Posted 07 April 2016 - 03:22 PM
Edited by Womak1992, 07 April 2016 - 04:38 PM.
#4422
Posted 07 April 2016 - 09:24 PM
#4423
Posted 08 April 2016 - 07:24 AM
Do you have any original style dash instrument cluster surrounds in black? Just need the surround/fascia and associated brackets to hold in place as have the instrument cluster already. For a 3 clock set up. Also do you have the fresh air vents for both sides? If so how much with postage in uk? Thanks
Yes I have a black 3 clock binnacle, you need the mounting bracket for the dials too? And you need the complete air vents, surround etc?
Hi, Do you have an airbox and fittings for a 1996 rover 1.3i cooper spi?
#4424
Posted 08 April 2016 - 08:14 AM
Yes the mounting brackets to and complete air vents surrounds and pipe to bulkhead panel basically the complete interior fresh air vents if possible? Thanks
#4425
Posted 08 April 2016 - 06:19 PM
