Classic Mini Spares
#4366
Posted 01 February 2016 - 02:20 PM
#4367
Posted 01 February 2016 - 06:20 PM
Hi do you have any turbos/mirage manifolds?
Afraid not at the moment.
Hi,
Do you have a carb choke cable retaining clip for hs4?
Thanks...
I do, will pm you.
Hi Do you have a passenger-side rear roof corner? Rust free obviously
thanks Chris
Hi Chris, I have them available, will pm you.
Disk drive shafts ?
Yep, bare shafts or with joints?
#4368
Posted 02 February 2016 - 12:42 PM
#4369
Posted 03 February 2016 - 08:18 AM
Hi Josh any chance you have pair of clubman side/indicator lights I have lens so not to fussed about them cheers
I don't at the moment unfortunately.
#4370
Posted 03 February 2016 - 12:40 PM
Hi Josh
Do you have driver and passenger side front roof corners?
Ger
#4371
Posted 03 February 2016 - 02:55 PM
Hi Josh
Ger
Hi, yes I do, will pm you.
#4372
Posted 04 February 2016 - 10:47 PM
Hi Josh. I need a replacement fresh air duct (minispares EAM7437). The duct from my 1974 car is brittle, cracked and perforated, and hopefully, you have an ample supply of newer ducts. I don't imagine there is much demand for this part.
I also need the bolt plate which is used to affix the air distribution box (minispares CZH1755) to the body. Minispares do not show the bolt plate in their catalog.
Thanks.
Posted 06 February 2016 - 08:33 AM
Thanks.
Hi Corey,
Yes I have the ducting. I have never tried taking the ring out of the plastic housing, I normally just sell it as it comes off the car.
Edited by MiniJosh92, 06 February 2016 - 08:34 AM.
#4374
Posted 06 February 2016 - 12:36 PM
Thanks.
Hi Corey,
Thanks Josh - would you kindly PM your price for the duct only, inclusive of lowest cost shipment to Amston, Connecticut, US.
#4375
Posted 06 February 2016 - 01:09 PM
Thanks.
Hi Corey,
Not a problem. I will get a price for the shipping and let you know.
#4376
Posted 09 February 2016 - 12:32 PM
Edited by Will16, 09 February 2016 - 07:07 PM.
#4377
Posted 10 February 2016 - 07:40 PM
Looking for pick up roof for the near future, if you see or hear of a decent one could you point them in my direction please, Thank you
#4378
Posted 11 February 2016 - 12:51 PM
Thanks.
Hi Corey,
Hi Josh,
Still waiting for the needed info.
Thanks.
#4379
Posted 11 February 2016 - 01:27 PM
How much would a drivers side steering arm for a disc brake hub and a decent steering rack be?
£20 plus delivery.
Will do.
Thanks.
Hi Corey,
Hi Josh,
Thanks.
Sorry for the delay, will pm you now.
#4380
Posted 11 February 2016 - 10:00 PM
Have you got a full wiper motor set, including wheelboxes and the outer sleeve bit? If so, how much posted?
Alex
