Classic Mini Spares
4780 replies to this topic
#4066 iToNiiCz
iToNiiCz
  • 683 posts
Posted 05 July 2015 - 02:26 PM
hi do you have any black seat belts in good condition ,front and back
thanks
#4067 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 05 July 2015 - 05:14 PM
thanks
Yes, definitely have fronts. Which type of rear ones are you after?
#4068 iToNiiCz
iToNiiCz
  • 683 posts
Posted 05 July 2015 - 05:32 PM
im looking for some for a mini city e in black what types are there -did not know there are different ones below is a pic of ones i would like_57%208_zpsb3d3txja.jpg
Edited by iToNiiCz, 16 July 2015 - 01:42 PM.
#4069 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 05 July 2015 - 07:45 PM
Okay, I will have to check on the rears. Lap belts, fixed three point like that or later inertia ones.
#4070 iToNiiCz
iToNiiCz
  • 683 posts
Posted 06 July 2015 - 01:51 PM
would like 3 point thanks like in picture thanks
#4071 chuffed
chuffed
  • 131 posts
Posted 06 July 2015 - 07:55 PM
Hi Josh,
Any good battery cables?
#4072 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 06 July 2015 - 10:44 PM
Hi Josh,
Hi, yes, inertia or pre-engaged starter?
#4073 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 07 July 2015 - 12:26 PM
Don't have any rears at the minute unfortunately.
Do you have any of the BELTPARK clips which go on the rear seatbelts? The ones that look like this but in grey, not black:
Quite probably, will check and get back to you.
Do you need two? Also had a quick look and is it actually possible to remove them from the belt without breaking them or cutting them?
#4074 iToNiiCz
iToNiiCz
  • 683 posts
Posted 07 July 2015 - 12:55 PM
could i have the front ones and do you have any good condition carpet with no hole colour black - how much for front seat belts thanks
#4075 ad53ggz
ad53ggz
  • 384 posts
Posted 07 July 2015 - 04:27 PM
MPI ignition barrel?
#4076 lewBlew
lewBlew
    Previously known as theboybradley.
  • 1,238 posts
Posted 07 July 2015 - 04:53 PM
I do need two... Is it not possible to remove them from the top (shoulder) end? If not, I might have 2 whole belts if you have them, depending on price.
#4077 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 07 July 2015 - 06:24 PM
Okay, yep got carpet, do you need a whole set with all the little bits too or just the main front and rear carpets?
Yep, pm heading your way.
I couldn't see a way of getting it off without cutting it or something, I will have a better look and check that I have two belts with them on.
#4078 iToNiiCz
iToNiiCz
  • 683 posts
Posted 07 July 2015 - 07:32 PM
full set and little bits of carpet would be good, how much for carpet and 2 front seat belts and postage
thanks
#4079 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 08 July 2015 - 06:23 PM
thanks
PM heading your way.
Had another look today and only got one grey belt with a good one on at the moment.
#4080 Harrison541
Harrison541
    A bowl of prawns, avocado and cress?
  • 498 posts
Posted 15 July 2015 - 08:33 PM
Have you got a steering column with all the brackets? I need the dash to steering rack bit, yellow bracket and the plate that goes above it. Oh and a drop bracket if you've got one but I can get that easy enough elsewhere if needed.
