Classic Mini Spares
#3736
Posted 28 January 2015 - 02:28 PM
#3737
Posted 28 January 2015 - 04:53 PM
#3738
Posted 28 January 2015 - 05:27 PM
OK, thank you. Do you have a spate mesh cover, or know where I could get/make one???
Sorry a cover for what?
Non servo master cylinder and brake pedal?
Yes, single or twin circuit master cylinder?
#3739
Posted 28 January 2015 - 08:10 PM
There's a mesh like cover on the front of the speaker, it protects the cone part. i cant even find the speakers on the net to show u
#3740
Posted 28 January 2015 - 08:23 PM
Ah okay, no afraid not, will let you know if any speakers turn up.
#3741
Posted 29 January 2015 - 11:47 AM
Have you a manual windscreen washer/bottle?
#3742
Posted 29 January 2015 - 01:24 PM
Yes, needs a good clean up.
#3743
Posted 29 January 2015 - 02:53 PM
Do you have the pump as well cheers
Edited by Richard19, 29 January 2015 - 02:56 PM.
#3744
Posted 29 January 2015 - 06:09 PM
have you got:
centre speedo cluster with binnacle
Clubman front grill
Clubman estate door cars. Full set. Doesn't matter on colour
Many thanks
Josh
#3745
Posted 29 January 2015 - 06:29 PM
Yes I should have a pump.
Hi josh after a few bits
have you got:
Clubman front grill
Many thanks
Josh
I don't have any complete centre speedo binnacles at the moment unfortunately.
I have clubman grilles.
I have some estate rear panels, not sure if I could make up a complete set though.
#3746
Posted 29 January 2015 - 08:19 PM
Do you have the pump as well cheersHave you a manual windscreen washer/bottle?
have you got:
Clubman front grill
Many thanks
Josh
If you can let me know if you have a full set that'd be great, also when you get in a centre clock binnacle etc
Got some pictures of the grills? And prices
#3747
Posted 29 January 2015 - 10:55 PM
#3748
Posted 29 January 2015 - 11:55 PM
have you got:
Clubman front grill
Many thanks
Josh
I will see what I can do on the trim panels and let you know. I have several grilles, some needing a bit of work, others not.
Double brake master cylinder..non servo type and the brake pedal if poss?
Okay, yes I have both of them, will pm you.
#3749
Posted 31 January 2015 - 05:16 PM
#3750
Posted 31 January 2015 - 05:32 PM
Hi josh have you got 12 x 6 minilites like the ones midlandwheels have and posted to st87lz many thanks tsymes
Hi, the widest 12" ones I have at the moment are 5.5" wide.
