Classic Mini Spares
4780 replies to this topic
#346 mini tristan
mini tristan
  • 11 posts
  • Local Club: ubmc
Posted 16 March 2011 - 10:38 PM
hi, you wouldn't by any chance have inner wings new or used as im after a pair for a project that come without any, also you wouldn't have a single mamba wheel with the valve hole in the rim, sorry its a bit specific, thanks
Hi, I have a shell that I've been cutting bits off for people that still has the inner wings. I do also have a few odd mambas.
Cheers, Josh.
hi, you couldnt by any chance get a photo of any of the mambas as im specificly after one with the valve hole in the actual rim and how much would you want for one including postage if possible, thank you
#347 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 16 March 2011 - 10:44 PM
Cheers, Josh.
I will check if I have any of that type & get a pic tomorrow - pm me your e-mail address.
#348 Frank the Tank
Frank the Tank
  • 530 posts
  • Local Club: Yet to find one local - ish
Posted 19 March 2011 - 09:15 PM
I don't suppose you have the wee plastic hose that comes out from the air filter (89 Mini City) or failing that a complete air filter?
Regards,
Andy.
#349 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 19 March 2011 - 09:20 PM
Have you got any rear subframe mount pins ? if so how much posted ?
Dan :genius:
#350 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 19 March 2011 - 09:40 PM
Regards,
Andy.
Dan :thumbsup:
Pm's on their way to both of you shortly :genius:
#351 myredmini
myredmini
  • 3,211 posts
  • Name: Dan
Posted 19 March 2011 - 09:43 PM
Spot On! :genius:
#352 miniallsort
miniallsort
  • 4,723 posts
Posted 21 March 2011 - 09:30 AM
hi have you got any rear seatbelt in black drivers side door catch and indicator unit
#353 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 21 March 2011 - 06:57 PM
what sort of rear belts are you after? I have door catches, not quite sure what you mean by indicator unit?
#354 miniallsort
miniallsort
  • 4,723 posts
Posted 21 March 2011 - 08:45 PM
hi mate rear seat bells for the back seats static front indicator unit :) and drivers door catch mechanism
#355 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 21 March 2011 - 08:58 PM
I'll pm you.
#356 The Goot
The Goot
  • 18 posts
  • Local Club: Mini WIPS
Posted 22 March 2011 - 07:48 PM
Hi Josh,
Do you have upper & lower padded dash, and both front disc hubs?
Juan
#357 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 22 March 2011 - 10:06 PM
Hi Josh,
Juan
Hi, yes, I assume you're after black dash rails?
#358 bettzy64
bettzy64
  • 17 posts
Posted 22 March 2011 - 10:09 PM
Do you have a half decent toe board/front floor/bulkhead that i can come and chop off a shell?
#359 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 22 March 2011 - 10:16 PM
Quite possibly, I'll check tomorrow & let you know.
#360 danny164
danny164
  • 28 posts
Posted 23 March 2011 - 12:06 AM
hey wondering if you have a complete wiring loom for a 1275 carbed engine? also looking for the four bolts that attach the rear subframe, the ones that sit at the end of the sills on the heel board if you have either please let me know and costings, also postage to portsmouth also looking for a passenger side door in good condition i.e only needing touching up/painting ideally also if there is a pair of the same standard that would be good, looking for the internal hinged ones,
cheers man.
