Front loom for a 1990 checkmate 998 please ??
Yeah, will just have to double check it's a good one and get back to you.
Posted 13 August 2014 - 10:47 PM
Posted 14 August 2014 - 11:27 AM
Posted 14 August 2014 - 06:10 PM
pm heading your way.
Posted 18 August 2014 - 11:12 PM
After a wheel hub and also a gearlinkage as had to cut mine to get engine out...
Do you have any?
Posted 19 August 2014 - 08:21 AM
Do you have any?
A front or rear hub? And I presume a rod change type gear linkage?
Posted 19 August 2014 - 08:15 PM
Do you have any?
Front wheel hub believe was passenger side but will need to check
And yes the Rod Type Change
Posted 19 August 2014 - 10:27 PM
Posted 20 August 2014 - 05:15 PM
Do you have any?
Okay that's fine, I have them. Only thing is I am away on holiday this week so drop me a message on Monday and I can sort them out.
Cheers, Josh.
Hi mate, are you a public or private breakers, as I'm not far from Ashford so might be easier to pop down for ALL the parts I need!
Cheers.
Your welcome to come and see what I've got. Will have to be next week though as I am currently away on holiday this week.
Posted 20 August 2014 - 07:16 PM
I am looking for a pre engaged starter solenoid ?
Posted 20 August 2014 - 08:26 PM
I have pre-engaged starter motors.
Posted 21 August 2014 - 04:30 AM
Posted 21 August 2014 - 07:52 AM
Hi, looking for a few things as trying to restore a 1979 special.
7.5 discs to convert from drums ( I know 8.4 are easier to get so might have to go that way)
Exaction wheels if can get disc as above
Center consul
Case for three clock from 1275 clubman
Bumpers from a clubman
Also looking for stage one for the 1100 engine ( stage two etc if available )
Hi,
I have a 7.5" disc setup, exacton wheels, clubman ials and surrounds and bumpers. I don't have any special centre consoles at the moment or worked small bore heads.
Thanks, Josh.
Posted 21 August 2014 - 08:35 AM
Posted 21 August 2014 - 09:51 PM
That's great can you give some prices and pictures. I live in Northern Ireland (bt51) so will need posting prefer this, if not my family live in Bromley they could maybe pick up and sort for me. Thanks
I am away on holiday this week so, message me next week and I can sort it out.
Thanks, Josh.
Posted 22 August 2014 - 10:01 PM
Do you have any?
Cheers, Josh.
Cheers.
