Classic Mini Spares
#301
Posted 05 March 2011 - 11:21 PM
I'm after a 1275 Verto flywheel, if possible with clutch assembly. Bell housing bolts & starter motor would be nice as well. Would consider buying (& collecting) blown up/seized engine if cheap.
Got anything?
Pegleg
#302
Posted 06 March 2011 - 12:16 AM
Hi Josh,
Got anything?
Pegleg
Hi, I have clutch assys inc flywheels, I'll pm you.
#303
Posted 06 March 2011 - 09:20 AM
Let me explain. I've bought a Metro Turbo engine from someone who took the flywheel off to put on another engine some years ago. I need a flywheel & hope that it will be the same for all of the Verto 1275 engines - or if it isn't that I can machine it to fit. The turbo clutch plate is 190mm instead of the standard 181mm. The pressure plate is probably different for the turbo as well but even if I buy a new one I would still need the attachment bolts.
What I need: Verto flywheel
What I'd like: starter motor
Anything else as a bonus: turbo clutch assembly, any bolts to screw together clutch, bell housing, bell housing end cover, starter motor...
Pegleg
#304
Posted 06 March 2011 - 01:57 PM
#305
Posted 07 March 2011 - 07:21 PM
I'm looking for a rear subframe and possibly a gearbox/diff (if the price is right) and any nice wheels if you see them as i need a spare set for when mine are painted!
Thanks,
fordy
#306
Posted 07 March 2011 - 08:55 PM
hi josh,
Thanks,
fordy
Hi, I've got subby's, boxes & diffs. What size rims are you after?
Cheers, Josh.
#307
Posted 07 March 2011 - 09:18 PM
Andy.
#308
Posted 07 March 2011 - 09:22 PM
Hi Josh , do you have the voltage stabilizer from the back of the central speedo?
Andy.
Hi Andy, yeah got them I'll pm you.
#309
Posted 07 March 2011 - 09:48 PM
hi josh,
Thanks,
fordy
Cheers, Josh.
How much are the subbies going for?
10's or 13's, again, how much?
Dan
#310
Posted 07 March 2011 - 09:54 PM
hi josh,
Thanks,
fordy
Cheers, Josh.
Dan
I'll pm you Dan.
Cheers, Josh.
#311
Posted 08 March 2011 - 08:21 AM
Do you have a set of GAZ lowered shocks by any chance?
Cheers mate. Nathan.
#312
Posted 08 March 2011 - 08:50 AM
Josh,
Hi Nathan, I think I have got some gaz but, I don't think they're lowered ones.
Cheers, Josh.
#313
Posted 08 March 2011 - 10:56 AM
Josh,
Cheers, Josh.
Damn, any chance you cold measure them for me? GAZ lowered should be 215mm closed, and 292mm open, from the pin centers.
Cheers mate.
#314
Posted 08 March 2011 - 03:37 PM
thank you
#315
Posted 08 March 2011 - 09:22 PM
Josh,
Cheers, Josh.
Cheers mate.
I'll measure them tomorrow & let you know.
hi, I am after a engine bulkhead crossmember (the one where the brake clutch and mastercylinder sits on and the wheelsuspension brackets are attached to on both side on the outside of their inner wings) Preferably whole lenght or drive-side only. If you can help can you send me a picture and agree on a price.
thank you
Hi, I have shells I can cut one from.
