Classic Mini Spares
#286
Posted 03 March 2011 - 06:41 PM
#287
Posted 03 March 2011 - 08:10 PM
#288
Posted 03 March 2011 - 10:37 PM
hi josh, have you got a 3 way brake pipe joiner from a rear subframe and also a pair of the plastic windscreen vents that slide on to the top dash rail, not the y shaped piece just the top trim
Hi, yep got those bits, I'll pm you in a sec
you alright just wondering if you have any black boot handles with keys? if so how much? also have you got any black alloys. im from whitstable. cheers Aaron
Hi Aaron, what size wheels are you after?
Hi mate, I need a couple of shell cuts. I need most of the parcel shelf and a transmission tunnel cut (four bolt subframe type if that makes a difference).
Hi, I have some the parcel shelf can be cut from but is your tunnel the old remote type?
#289
Posted 04 March 2011 - 09:37 AM
12,6 or larger cheers Aaron
Edited by Aaronwild, 04 March 2011 - 05:15 PM.
#290
Posted 04 March 2011 - 07:43 PM
sorry none at the moment, bit over-run with 10's & short on 12's & 13's.
#291
Posted 04 March 2011 - 07:54 PM
Hi, yep got those bits, I'll pm you in a sec![]()
Hi Aaron, what size wheels are you after?Hi mate, I need a couple of shell cuts. I need most of the parcel shelf and a transmission tunnel cut (four bolt subframe type if that makes a difference).
No mate its a rod change type - but our car is such a bitzer I have no idea what it was originally! At the moment the tunnel is made of three bits of metal that have been self tap scrwed together then welded with the screws still in! Its a rod change type tunnel that we need.
#292
Posted 04 March 2011 - 07:59 PM
ok, I'll pm you now
Cheers, Josh.
#293
Posted 04 March 2011 - 08:36 PM
#294
Posted 04 March 2011 - 09:31 PM
Do you have any drivers side door hinges which'll fit a 1975 mini 1000, and a cheap set of front door cards (preferably black)?
Hi, got hinges but no good black door cards at the moment I'm afraid.
#295
Posted 04 March 2011 - 10:38 PM
Pm'd
#296
Posted 04 March 2011 - 10:44 PM
Pm'd
replied
#297
Posted 05 March 2011 - 11:44 AM
#298
Posted 05 March 2011 - 01:41 PM
do you have a top dash rail in decent condition and a black boot handle with keys ? cheers Aaron
yeah, I'll pm you in a sec.
#299
Posted 05 March 2011 - 07:29 PM
#300
Posted 05 March 2011 - 07:32 PM
got any sports pack arches? and a bonnet arm? mine dissapeared....think some little rodent stole it....havent a clue why
sorry no sportspacks at the moment. Got bonnet catch hooks, I'll pm you.
