Classic Mini Spares
#2686
Posted 07 February 2014 - 06:54 PM
#2687
Posted 07 February 2014 - 07:00 PM
Hi do you happen to have any badge/spotlights bars? Ones that don't need the grille to be modified. Suitable for 4 spotlights.
Unfortunately not at the moment.
#2688
Posted 07 February 2014 - 07:11 PM
Could you drop me a pm if you get any in thanksHi do you happen to have any badge/spotlights bars? Ones that don't need the grille to be modified. Suitable for 4 spotlights.
#2689
Posted 07 February 2014 - 07:12 PM
Certainly will. I do have one but, it's it's a bit bent and twisted.
#2690
Posted 08 February 2014 - 03:04 AM
#2691
Posted 08 February 2014 - 08:25 AM
Im after a high hp engine and box with a pair of disk hubs. Happy for mpi, a or a+, emissions not an issue. What do you have? Shipped anything to aus before?
Unfortunately I only have std engines at the moment.
#2692
Posted 08 February 2014 - 08:59 AM
All I can offer at the moment is the rear end of a shell I will be cutting up shortly. The rear quarters aren't that good but, the rear panel etc is good.
How much would you want for the entire length of the hinge panel including the seams at the ends, upto the height of the rear lights or higher if that helps you. Maybe cut across the lights? http://www.minispare.../MS20.aspx|Back to
Also a working indicator flasher for 1984 mini. No side repeaters.
Thanks.
#2693
Posted 08 February 2014 - 09:38 AM
Thanks.
£25 for the panel. Pm me if you want it. Cheers.
Edited by MiniJosh92, 08 February 2014 - 09:38 AM.
#2694
Posted 09 February 2014 - 08:52 PM
Have you got a decent 202 head?
Got any 266 or 276 style cams?
I think I may have a head but, no cams of that description at the minute. Will let you know if I have any luck with the head.
Any luck mate?
Sorry no decent 202's at the minute, will let you know if any come along.
I have a head now, just let me know if you have any fast road cams in.
#2695
Posted 09 February 2014 - 09:07 PM
Any luck mate?
Will do.
#2696
Posted 10 February 2014 - 08:38 AM
OK, What 1275's with boxes do you have?
MG Metro, MPI?
#2697
Posted 10 February 2014 - 12:57 PM
MG Metro, MPI?
Carb and spi.
#2698
Posted 10 February 2014 - 10:03 PM
Do you have a brake master cylinder for std servo brakes
clutch master cylinder
Brake bias which is mounted below servo.
Headlining rod set and a black headlining
if so how much posted to Chester
Cheers Herman
#2699
Posted 10 February 2014 - 10:18 PM
Cheers Herman
I have all of the above with the exception of a black head lining, will pm you.
#2700
Posted 10 February 2014 - 11:23 PM
Thankd
