Front Windscreen Aperture Size.
Posted 16 December 2010 - 01:26 PM
Posted 16 December 2010 - 01:43 PM
Posted 16 December 2010 - 05:21 PM
I have always believed that all Mini screens were the same size at the front and that only the rear was smaller on the Mk.1, but I could be wrong. I do know that when I fitted a heated gold-filament laminated screen to my Mk1 it was the same as a friend fittted to his 1994 rally Mini as they came from the same batch.
Edited by Cooperman, 16 December 2010 - 05:36 PM.
Posted 16 December 2010 - 06:11 PM
Posted 16 December 2010 - 07:17 PM
Posted 16 December 2010 - 09:07 PM
Posted 16 December 2010 - 09:27 PM
Posted 17 December 2010 - 12:11 AM
Thanks for the replies folks. Exactly what I was after.
Yes, I suspect +/- 1 mm is within tolerance for the screen rubber.
I guess you are fitting a new scuttle rail. I's strange how a '60's Mini will have no scuttle panel rust, but a 1998 one will be completely corroded away.
Posted 17 December 2010 - 12:14 AM
I have a mk1 screen and it definately looks smaller
Which end of the car are you looking at???
Posted 17 December 2010 - 10:06 AM
Posted 25 February 2017 - 11:31 AM
all mini classic front windscreens are the same size
only the thickness vaireys & rubbers changed to accommodate this
Edited by sledgehammer, 26 February 2017 - 12:38 AM.
Posted 26 February 2017 - 12:24 AM
Posted 26 February 2017 - 12:39 AM
almost like the walking dead
Posted 26 February 2017 - 09:45 PM
Posted 26 February 2017 - 11:28 PM
the edges are quite rough where the joins are
no wonder they leak
some of the new screen seals are from straight rubber , extruded without corners so the inside is too big
any ideas how to get the bunching out at the corners ?
