It Begins...... Minus.
#121
Posted 08 February 2012 - 07:22 PM
Anyway I think once I have the money tub the arches and tub the suspension turrets. I have my eye on a fibreglass kit on this one website that Abuglar showed me. Then I have found another website that sell specialised paint that is better than por15 and is supposed to be the mutts nuts for my front subframe :)
Good progress though with the turrets though :)
Regards Blue
#122
Posted 24 February 2012 - 09:44 PM
Got the passenger side door all fitted up. Definately not going to get any concourse points with the panel gaps, had to use a few shims to get it to look this good. Was a right pig! Strangely though i've now got the drivers one in and it was a doddle and lines up a lot better. Both seem to drop a bit at the top. I'm not to fussed though as its a racecar ;).
Ive also fitted the bootlid, got my steering column and steering rack where i want it almost. Will need a bit of cutting to get the rack to turn. Also making up some bits so i can mount the seat.
I've also got a internal gear linkage kit to fit.
Been having lots of trouble trying to get the front subframe in. Just won't line up right with the pre drilled holes. Im going to drill out the threads in the subby and give it another try with just nuts and bolts so i have a little more room to play with.
Also got a picture if my new daily. Basically it's a prototype zr x210 only one built, would of had a 2.0L K series with 210bhp but it was removed for a 160 lump with a few nice mods before it was sold of at auction when they went bust, has some rediculous brakes and lots of other one of bits. I did have a lovely old honda civic ed7 but i got a good price and sold it on.
Edited by jonny f, 12 July 2014 - 10:51 PM.
#123
Posted 25 February 2012 - 05:19 PM
Keep up the good work
Regards Blue
#124
Posted 25 February 2012 - 06:42 PM
dont supose you know how much are the rear windows going to work out at as im going to want a pair at some point :)
#125
Posted 25 February 2012 - 08:29 PM
Blue
#126
Posted 25 February 2012 - 08:42 PM
thats what i mean buddy, how much are they doing them for?, id cut some myself from the pile of perspex / polycarbonate at my dads work but i have opening windows and i want rid as there too easy to open! (and prob leak haha) so if its not major expensive its worth ordering a pair if it is ill buy glass ones off ebay
good luck with your build anyway, are we expecting you at MITP in it?
#127
Posted 25 February 2012 - 08:52 PM
In terms of plastic for performance it is expensive what I ordered coming to £160 just for the rear quarters, but they are E-marked so legal for me to put my minus through an IVA. I did make my own polycarbonate windows (before the law changed for putting a vehicle through an IVA) and to be honest its easy as long as you have another window to take the size from, you can cut polycarbonate with a jigsaw and it is a lot stronger than perspex.
#128
Posted 25 February 2012 - 09:20 PM
cheers bud
keep up the good work
#129
Posted 26 February 2012 - 04:22 PM
Looking good Jonny ;) I can see what you mean about the panel gaps on the door! Are they the arc angel ones? Also what lock are you using on your boot-lid? I've given my project a quick update :)
Regards Blue
Yea they are, im not to fussed. They were cheap and it shouldn't look to bad when its painted.
I've got boot pins on each corner. I did just want a mk1 handle but the bootlid wouldn't sit flat enough and needed pinning at each corner.
I still might fit the handle. I had a quick look at your update, its coming on fast now, the turrets are looking good, you did it completely different to the way i did it. In hindsight yours looks like a better way of doing it haha.
#130
Posted 26 February 2012 - 06:24 PM
Regards Blue
#131
Posted 26 February 2012 - 07:01 PM
#132
Posted 26 February 2012 - 10:09 PM
Regards Blue
#133
Posted 28 February 2012 - 08:23 PM
Black chrome does look amazing!
#134
Posted 28 February 2012 - 08:26 PM
Also got a battery box. Was going to mount this in the boot, now thinking behind the passenger seat would be nicer.
Edited by jonny f, 17 March 2013 - 06:40 PM.
#135
Posted 28 February 2012 - 10:25 PM
I actually can't stand normal chrome and think it looks very tacky in my opinion but i think black chrome has a certain finesse about it. I intend to get my wheel nuts re plated in it too because the crappy zinc plating that is already on them is rubbish and they have started to rust even though they haven't seen the outside!! They are the ones from huddersfield spares which come with the 'super trax' (tuner wheel nuts). They look cool but like I say and they say on the website they will rust instantly!!
Have fun with your new bits Jonny
Regards Blue
