It Begins...... Minus.
910 replies to this topic
#856 jonny f
jonny f
  • 1,485 posts
  • Local Club: Boxhill Mini Club
Posted 21 April 2018 - 08:31 PM
Got the inlet made by Alex from The Car Kitchen.
Very happy with it. Its got nice big bellmouths inside, boost take offs and the IAT sensor are underneath.
I had to modify the TB so the linkage sat 90deg further round. This meant I could put the TPS at the top allowing just enough clearance for the bonnet. Took quite a few goes to make a throttle cable bracket as its all very snug.
Im just waiting on some O rings and some barbs for the air take offs and I can bolt it up tight.
31047179_10156465553616654_3850172464122
#857 jonny f
jonny f
  • 1,485 posts
Posted 21 April 2018 - 08:34 PM
Got the parcel shelf done so the back end is almost finished just need a hand to tighten the window bolts..
30730000_10156463125471654_5953484645520
Edited by jonny f, 21 April 2018 - 08:35 PM.
#858 jonny f
jonny f
  • 1,485 posts
Posted 24 April 2018 - 09:34 PM
Its almost there.
It wont start though! I am sure its timing related. It fired up for a few seconds but not much since.
Unfortunately my timing light has packed up. Hopefully figure it out tomorrow with a borrowed one.
Im using a map Will k kindly sent me. Everything looks good in the software to me but Im no expert. Just used SCs setup guide.
31183467_10156473900731654_8408836003179
#859 jonny f
jonny f
  • 1,485 posts
Posted 26 April 2018 - 11:17 PM
Were all good! Well mostly. Cars a bit of a mess!
Turned out to be the crank sensor gap, which is frustrating as Ive never had an issue setting it before. I must of moved it a good 5-6 times with no luck the other day.
Took it to SCS and after some diagnosis it was adjusted again and worked fine.
Was then onto mapping, which went very well :).
175bhp and 180lbft at 15 psi.
31378693_10156478423251654_4662309372016
There is a restriction somewhere in either the exhaust or inlet. Personally think it was the last minute lash up on the intercooler, outlet is 38mm ID and goes through a nasty bend before opening to 47mm. It didnt want to go much over 15psi. Some further work to do.
I also need to change the rad piping to the other side of the engine. Its to tight at the moment.
Worst bit was on literally last power run, one of the tyres I had borrowed delaminated. Nothing that cant be fixed. Just frustrating!
31363365_10156478423241654_1104880332601]
#860 Baldspeed Racing
Baldspeed Racing
  • 1,191 posts
Posted 27 April 2018 - 06:48 AM
Good power figures dude and given the weight of the car I bets shes gonna be a right giggle to drive. Gutted on the tyre so I guess as the arch is off its ripped off as the tyre went?
#861 GraemeC
GraemeC
  • 7,431 posts
Posted 27 April 2018 - 06:54 AM
Oof - what a shame on the tyre, bet there were some brown trouser moments as that let go!
Better than happening on the road or strip though.
#862 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 27 April 2018 - 07:05 AM
Love this, I like reading your updates because it shows me what I could have done with my first Minus if I didn't have a wife and kids and mortgage and..... I dread to think what you've spent on this, I bet you've stopped counting!
Is the radiator thing staying on the front like that or are you going to find a way to hide it?  It'll look far neater if all the speed is hidden away.  Someone should make a radiator the same size and shape as the grille so that it can be dropped in there and still look close to normal.
#863 Steve220
Steve220
  • 5,029 posts
  • Local Club: BMC
Posted 27 April 2018 - 08:54 AM
Amazing work, Jonny! How do you run your engines in?
#864 jonny f
jonny f
  • 1,485 posts
Posted 27 April 2018 - 01:23 PM
Should be fun, it wasnt slow anyway haha.
Yea, arch, headlight bowl, headlight ring (not the headlight somehow, theyre plastic :)), wing mirror and done some damage to the top of the wing, its blow the GRP near the scuttle. All the black marks will polish out.
#865 jonny f
jonny f
  • 1,485 posts
Posted 27 April 2018 - 01:38 PM
Yes, there is some bits stuck in there ceiling! My instant thought was my clutch or something had let go as I was the other side of the car.
The tyres were some old perelli that my mate had as spares, the RR doesnt like 10s they sit to low and touch the built in jack. He was kind enough to lend them to me for the day. They looked perfect but were a bit old.
Just do it anyway. Only live once. to be honest I have a mortgage etc, just got lucky and I have a job I love that allows me a lot of time etc for my hobbies.
Its the same radiator I used last year. Grille covers it, its on buttons I made. Was just off in the photos. Get a bit more air flow on the dyno as there fan wasnt the widest.
Ive only built 3. Every time has been different. This was just run in on the dyno. So before any peak power runs it was all mapped down low with some high load low rpm so that would bed the rings in.
Last engine, I knocked Cam in at 2000 rpm as soon as it started for about 10-15 minutes. Did a few high load low rpm pulls up a big local hill for about 100 miles, changed the oil and went to the rolling road.
#866 slack
slack
  • 65 posts
Posted 28 May 2018 - 06:26 PM
Got a new rear view mirror, its literally an exact replica of a longacre but £16 delivered from eBay. I then stripped it down removed the metal backing etc and glued the glass to the brackets. Along with taking a bit of those. Very happy with it.
Got the plastic screen fitted to, was very tight!
29542868_10156404541401654_2178748352944
hi, here i can find brackets like this for safety device roll bar?
#867 jonny f
jonny f
  • 1,485 posts
Posted 30 May 2018 - 09:21 PM
They came with the mirror
#868 jonny f
jonny f
  • 1,485 posts
Posted 08 December 2018 - 07:18 PM
I have not updated this for a while.
I have not actually used the car much this year. held back from last years 12 trackdays! managed to get to MK1 Action day, Goodwood RR gathering, Castle Combe mini day and a last chance trip to Rockingham. Cars performed really well overall.
Couple of little niggles to sort out. Seems to have started to overboost a little and the dump valve is a little slow.
Got some quite big plans to get done over winter, will see in due course!
In the meantime i've dropped a few Kg's here and there.
Worked with a friend to produce these, PM me if you want a set.
45228803_10156955505381654_1549930388615
45081596_10156955506146654_8382779171033
Pretty good saving over a lightenned standard set.
45062842_10156955505661654_3185746967665
CK engine steady decided it would give up.
45128879_10156955505636654_6414071363476
With the spreaders etc it was actually pretty heavy.
45259239_10156955505526654_5742433822360
Managed to get it down a bit with some Ti spreaders, bolts and a bit from Owens fab.
45235058_10156955505551654_3807742898816
Looks a bit better to imo
45119287_10156955506041654_2537936101222
Made some CF door striker plates
45198420_10156955505966654_2238070413852
Replacing these
45252657_10156955505746654_1738052211037
Changed the ARB mounting bolts
45184344_10156955505956654_1977844203723
Not much dropped out but they look a lot neater
45216840_10156955505976654_5981402061793
This was a fun one
45122157_10156955506291654_2165441799617
Could do with a tidy up but want to check they won't fall to bits first!
45178831_10156955506226654_1600805367158
So 1.125 kg with that effort, not massive but seems worth it.
Also finally got round in finshing of my column
45196111_10156955506266654_6311713548259
My gearlinkage has been slowly parting ways with the body so i got one of these and am going to get some mounts done of the cage centre tube, should help me find some gears easier.
45302310_10156955506116654_2031601955725
Managed to pick up another Tillett seat for the passenger side, this is an old B6 and comes in at 4.6kg with the pads on, current seat is 8.7kg.
45795713_10156978989786654_6772609752967
As this one is base mounted and doesn't line up with the current holes i'm changing the seat mounts to accommodate it. Will be going tubular and somewhat lighter. Sticking with MSA regs at 25mm tube etc. Probably going to chop the drivers ones out to seeing as these are pretty bulky! Hopefully 5kg saving.
45855079_10156978989756654_5423063361354
45882077_10156978989771654_5662088599298
45896425_10156978989791654_5474618581113
#869 jonny f
jonny f
  • 1,485 posts
Posted 08 December 2018 - 07:19 PM
Got a bit more weight out :).
Was using slightly turned down minifins
46708216_10157009557476654_2967826430215
Have now fully turned down a set to remove the rear lip part.
46512110_10157009557726654_3205086191787
Took a bit off a new set of cylinders
46836755_10157009557801654_2881558601871
46520177_10157009558151654_6347079395601
Standard rear backplate adjuster and cylinders
46525405_10157009558211654_4895999109527
DSN backplates turned down to match drum diameter with everything lightened, Ti fixings etc.
46847389_10157009558261654_4695625506345
Back plate to rear arm bolts
46703896_10157009558301654_6433010352480
Ti version
46520266_10157009558311654_3260318105414
Standard rear shoe weight
46525657_10157009558511654_1801158960087
Trimmed down a little
46513803_10157009558596654_4063356047782
Grease caps swapped to ally
46508522_10157009558616654_7729713128635
46520635_10157009558686654_5271729218017
Handbrake pins standard
46498436_10157009558851654_7704341622946
Ti version lightened a little further by drilling them out
46523469_10157009558951654_8801207709782
Inner quadrants of force racing beam
46518996_10157009559006654_6402939559864
Lightened the quadrants and used a Ti fixing
46513267_10157009559036654_6179457855809
Rear protech coilover damper pins and spacers
46514462_10157009559081654_6390639301809
Replaced with Ti bolts
46507648_10157009559191654_9059920528055
ARB bracket
46520403_10157009559241654_8462397513830
Not much, I might make these in Ti in the future
46712047_10157009559326654_4057817846367
All that is 2.4kg :).
#870 jonny f
jonny f
  • 1,485 posts
Posted 08 December 2018 - 07:20 PM
Have made some new handbrake levers. It is taking quite a bit of time to go through all these bits. Am getting there though.
48186175_10157043438686654_1620459158979
47488408_10157043438736654_1217334116987
Also made the rear ARB blades in Ti
47571237_10157043438786654_3204793425341
47575041_10157043438836654_6650997491988
482g saved with those.
