It Begins...... Minus.
910 replies to this topic
#766 Jayme 1275
Jayme 1275
  • 488 posts
Posted 09 November 2015 - 09:30 PM
That the adjuster that fits onto the bias bar?
EG shape? i had 1 of them for a while, fun little cars with plenty of potential.
No I have one in the line itself. They're designed to be used to limit the rears on single line systems but you can use them on dual line with the same effect. I didn't like the angles I got on the bar with the brakes adjusted how I wanted.
This on but paid less elsewhere.
http://www.demon-twe...GegjRoCQd7w_wcB
No EF shape. ED7 to be precise, I had one about 5 years ago and now I have another.
Ah cool dude, any pics of it? have a good friend has a nice wee 1 of the EF Shape civics, def getting harder to find these days; especially a good one
#767 jonny f
jonny f
  • 1,485 posts
  • Local Club: Boxhill Mini Club
Posted 13 November 2015 - 12:09 PM
I have a few from brands the other day, it was standard when i got it 3 weeks ago.
12219552_10153827775376654_6619527100827
12249666_10153827777201654_3137761022481
#768 Cavazzi
Cavazzi
  • 75 posts
Posted 13 November 2015 - 04:35 PM
A great car, the first car i raced when i got my race license at age 14. it was my grandfathers and i think it was a 1.4 but really light and fast.
#769 Jayme 1275
Jayme 1275
  • 488 posts
Posted 14 November 2015 - 12:19 PM
What the plans for it mate?
#770 jonny f
jonny f
  • 1,485 posts
Posted 15 November 2015 - 08:58 PM
Nothing much, just tidy it up slowly and improve it for track use. Need to chop the sill ends of and re do them and the paints poor all over.
Just put some s2000 brakes on it.
#771 jonny f
jonny f
  • 1,485 posts
Posted 27 November 2015 - 10:32 PM
Engine is almost ready to go :).
Water pump and controller are sorted and nearly everything is wired up.
12310007_10153856151726654_1882049035912
It's taken me a while to sort the actuator out but i'm fairly happy with this. Just needs tidying up and painting.
12309555_10153856151731654_3180795284735
Knocked up a new little dash with afr/boost gauge, oil pressure, voltmeter (in the post). Can see the water pump controller on the right, this also controls the fan.
12265722_10153856151706654_8423336362463
Fuel lines.
12308330_10153856562406654_8501989484350
I am waiting on an intercooler. I did want to sort something in the inner wing with a duct but i've given up searching for an intercooler of a standard car that would fit. Gone for a 2wd cossie behind the bonnet with a few holes in the bonnet. Although i'm going to try something a little different with the holes.
#772 Jayme 1275
Jayme 1275
  • 488 posts
Posted 30 November 2015 - 01:29 PM
Nice work mate, you had a chance to try the water pump out yet?
#773 jonny f
jonny f
  • 1,485 posts
Posted 30 November 2015 - 06:13 PM
No, i'm sure it will be fine though. They're rated quite highly.
Edited by jonny f, 30 November 2015 - 06:13 PM.
#774 jonny f
jonny f
  • 1,485 posts
Posted 09 December 2015 - 09:21 PM
Changed my mind again on an intercooler. Found this of a mazda 323gtx. It fits perfectly, its not massive but with a nice duct it should be quite capable.
12321548_10153880520061654_7284443896945
12311120_10153880520111654_4130127260890
Finished up the Actuator.
12316605_10153880520136654_8638182608064
#775 jonny f
jonny f
  • 1,485 posts
Posted 28 December 2015 - 08:48 AM
I've started on a duct for the intercooler. Hopefully it will get enough air through it. I will probably cover it in something to keep the heat away.
12370927_10153904500201654_8367867192720
#776 jonny f
jonny f
  • 1,485 posts
It's close :D.
Duct is in after a bit of fettling and boost hoses roughly in place.
Also got an MG metro housing which helps get the hose in a better position for the rad. Thank you David! (Tadge44).
10473333_10153908377971654_9168343875047
My list of things to do is now quite short. Hoping it'll be up and running mid January.
#777 jonny f
jonny f
  • 1,485 posts
Posted 28 December 2015 - 08:49 AM
New plenum. Thanks Matt. Fits all good.
Slightly lower and wider to keep the volume the same. It clears my bonnet nicely. Only issue is now the carb doesn't! It's higher than it was on the old engine due to the engine being tilted forward and the turbo inlet sits higher.
12375052_10153911953066654_4945918556784
#778 leaky
leaky
  • 6,890 posts
Posted 28 December 2015 - 09:09 PM
Not read this in a while so just updated myself. Great work as always man. Bummer about the carb now not fitting under the bonnet. Got a plan to solve that or you just gonna raise the bonnet up at the back?
#779 jonny f
jonny f
  • 1,485 posts
Posted 28 December 2015 - 10:36 PM
Thanks, I filed the carb dash pot down a little and took a little off the bonnet as its pretty thick anyway and that's sorted it.
#780 jonny f
jonny f
  • 1,485 posts
Posted 28 December 2015 - 10:39 PM
Hopefully this the final mock up in the engine bay minus a oil catch can and steel rocker cover.
I just need to go through and tighten everything up.
10669043_10153924047681654_5674392180360
I then have....
Exhaust to fit
Fuel tank to bolt in
Fuel lines
Base map mj
Wiring tidy up (to acceptable level, will rip it all out next year).
Fingers crossed it works lol.
6 user(s) are reading this topic
0 members, 6 guests, 0 anonymous users
