It Begins...... Minus.
910 replies to this topic
#751 jonny f
jonny f
  • 1,485 posts
  • Local Club: Boxhill Mini Club
Posted 18 August 2015 - 10:35 AM
Cheers bud i`ll have to get one of those ordered. Got a 3.1kg Red Top 8 at the moment....it all adds up! I was only there in the morning as I had to get back home, fuse box melted itself anyway on last run! Shame about the shaft. Did you manage to get it fixed and get a run in at all?
PS: we have the same rear beam!  :D
Yea it does, what does your car weigh? I imagine the engine really helps drop the weight.
I got it fixed but it was way to late by then and i was supposed to be leaving early but failed on that. Should probably trailer it next time.
Awesome, i love Carls stuff.
Top top car everytime i see it such workman ship has gone into this, and she is always loosing the weight lol
Thank you :)
#752 duds100
duds100
  • 231 posts
Posted 18 August 2015 - 12:04 PM
Yeah R1 really helps. Engine & Gearbox weigh 65kg. Diff, reverse box, sprocket & chain add a fair few back on though but it`s still comfortably under 500kg with a full tank, without me sat in it.
I always tend to trailer mine to and from Tracks, it just takes the worry away!
#753 jonny f
jonny f
  • 1,485 posts
Posted 18 August 2015 - 12:09 PM
That's good! I'm at 548kg. I trailered it to goodwood last week, trouble I have is its my dads trailer and I don't have a license to use it.
Need to borrow him every time which is a pain.
Must book in and do my test.
#754 IainStallard
IainStallard
    I am the first status holder 2014.
  • 1,114 posts
  • Local Club: Box Hill Mini Club, CCMOC
Posted 18 August 2015 - 12:23 PM
What car are you towing with and what trailer? I know I'm allowed to tow as long as the tow car and trailer and car combo doesn't weigh more than 3500kg, I'm younger than you on a basic license
#755 jonny f
jonny f
  • 1,485 posts
Posted 18 August 2015 - 04:01 PM
Looking at the rules again. I could definitely use his trailer with my civic type s diesel.
I always thought you weren't allowed to tow a braked trailer for some reason.
#756 Minidarren83
Minidarren83
  • 1,207 posts
Posted 18 August 2015 - 04:35 PM
Jonny I missed you at mitp the only time I saw you was when you was being pushed out the gate I was 2 cars back from you and didn't even notice. I'm sure I'll get to see your car one day
#757 mad mk1
mad mk1
  • 746 posts
  • Local Club: TurboMinis.co.uk
Posted 18 August 2015 - 05:16 PM
wow that's light! I seen you at pod but every time I went to chat you was firing up or I was lol.
jonny the only down side with towing is there is no real shake down on the car, as I found it was always the little silly stuff would go wrong.
#758 jonny f
jonny f
  • 1,485 posts
Posted 28 September 2015 - 09:58 PM
Last shot of the 1380 :)
12049283_10153742065956654_8591321152031
Coming out
11146470_10153742065976654_3370848696742
12063423_10153742066031654_7424465164616
Rebuilt the carb
12065702_10153742066061654_5923111372184
12065607_10153742066066654_5129885362227
Big hole!
10157269_10153742066096654_3907378292627
1293 in
12032190_10153742581751654_8275361859083
First issues to sort are, AFR sensor fouls bulkhead/steady and Actuator fouls steady.
#759 jonny f
jonny f
  • 1,485 posts
Posted 22 October 2015 - 04:31 PM
1.8kg off the roof and 1.2kg from loosing most of the dash rails.
12141681_10153787197476654_9154331850317
+200g of dust!
#760 Jayme 1275
Jayme 1275
  • 488 posts
Posted 07 November 2015 - 06:27 PM
Hi mate
Looking through your thread there at your pedal box, what type of wilwood box did you go for in the end (pedal ratio), did you have any clearance issues fitting it it around the column? also what size master cylinders did you opt for?
Have to order the box for my own project this week and id like to try go with something that is proven to work on a mini.
Cheers, sorry for all the questions
#761 jonny f
jonny f
  • 1,485 posts
Posted 08 November 2015 - 05:10 PM
Hi mate
I use this pedal box
http://www.rallydesi...oducts_id=15586
No clearance issues
I use these cylinders .625 on fronts, .75 rear and .625 clutch. I think! Can't remember lol. http://www.rallydesi...th=562_582_2043
#762 Jayme 1275
Jayme 1275
  • 488 posts
Posted 08 November 2015 - 06:05 PM
Thanks mate, thats a great help, hows the turbo build going?
#763 jonny f
jonny f
  • 1,485 posts
Posted 08 November 2015 - 06:52 PM
No problem. I also have a bias valve on the rear as I found it helpful when setting up the brake balance. I started getting some strange angles on the bias assembly on the pedal box.
Not bad, not far off but I keep playing with an early 90's civic at the moment so not done much with it.
#764 Jayme 1275
Jayme 1275
  • 488 posts
Posted 08 November 2015 - 07:11 PM
That the adjuster that fits onto the bias bar?
EG shape? i had 1 of them for a while, fun little cars with plenty of potential.
#765 jonny f
jonny f
  • 1,485 posts
Posted 09 November 2015 - 08:34 PM
No I have one in the line itself. They're designed to be used to limit the rears on single line systems but you can use them on dual line with the same effect. I didn't like the angles I got on the bar with the brakes adjusted how I wanted.
This on but paid less elsewhere.
http://www.demon-twe...GegjRoCQd7w_wcB
No EF shape. ED7 to be precise, I had one about 5 years ago and now I have another.
